gsr bore or a b20 block
Old Feb 22, 2008 | 09:50 PM
jdmgeezer's Avatar
Default gsr bore or a b20 block
i am planning to go all motor on my gsr with the gsr head debating on getting a b20 block or just bored out my gsr block if i do bore my gsr how far do i bore it to and what pistons
Old Feb 22, 2008 | 10:14 PM
all-mtr-teg's Avatar
Default Re: gsr bore or a b20 block (jdmgeezer)
You can go up to 82mm on your gsr block. Check your pm
Old Feb 23, 2008 | 06:53 AM
ekBlackHatch's Avatar
build a oem stroker kit... ls rods and crank with some 82mm pistons should see like 1.880cc so almost 1.9litir just make sure u use arp bolts new bearings and have it all balanced you could even shotpeen the rods for peace of mind
Old Feb 23, 2008 | 09:14 AM
dthug's Avatar
Default Re: (ekBlackHatch)
i would NOT do 82mm on stock sleeves.your just asking for problems. 81.5 the most unless sleeving then you can take it to 84 mm
Old Feb 23, 2008 | 09:45 AM
b.series's Avatar
Default Re: (dthug)
if sleeved u can even take take it to 85mm
Old Feb 23, 2008 | 10:54 AM
Default Re: (dthug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dthug &raquo;</TD></TR><TR><TD CLASS="quote">i would NOT do 82mm on stock sleeves.your just asking for problems. 81.5 the most unless sleeving then you can take it to 84 mm</TD></TR></TABLE>
Why not, for NA builds, 82mm is fine as long as your clearances and tune are good. My 82mm build just turned over 12k miles, driven hard since it was built. I wouldn't go 82mm on a boosted stock GSR, nor would I go 85mm on a boosted stock B20 w/o sleeving.
Old Feb 23, 2008 | 10:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekBlackHatch &raquo;</TD></TR><TR><TD CLASS="quote">build a oem stroker kit... ls rods and crank with some 82mm pistons should see like 1.880cc so almost 1.9litir just make sure u use arp bolts new bearings and have it all balanced you could even shotpeen the rods for peace of mind</TD></TR></TABLE>
Good advice. You get the stoke of a LS/B20 crank with a bump in displacement, almost 1.9L like you said, but can use the GSR main girdle and no need for oil lines or b20vtec conversion kit.
Old Feb 24, 2008 | 05:32 PM
StorminMatt's Avatar
Just get that GSR resleeved and run 85mm pistons. This way, you will have a fairly strong and durable setup. You will not ruin your rod ratio by stroking. And you will not have the smog issues that you would have with a B20 block.
JeeK
Feb 26, 2015 04:46 AM
HksHaitian
Aug 11, 2011 05:10 PM
lakai_19
Mar 12, 2008 07:51 PM
JFG Kevin
Sep 6, 2006 09:22 PM
speedy108
Feb 10, 2003 01:13 PM
