Swapping shift linkage, Am i missing anything??
I need to switch out my shift linkage as its currently bent. Its hitting the heat shield and causing a really bad and annoying sound; its quite embarrassing actually. Anyone know if its pretty hard to remove? From what i know i have to remove the bolt from the shifter, the 2 bolts from the bushing, 1 bolt from the end bushing, and the spring pin. Anybody know if im missing anything??
That sounds like everything. Besides taking off the shift **** (common sense, I know) that shift linkage should drop right out.
Sweet, does anyone suggest energy stabilizer bushings, i heard theyre pretty great but im not to sure if its okay for daily driving. Also is it pretty easy to break the spring pin
I just stick with the stock stuff. I have no clue about any other bushings. as for the spring pin, it's a pain in the *** to get out but I don't see you breaking it. I've had to use an air hammer to get them out and nothing happened to it.
b18c4door
26
Nov 23, 2007 04:47 AM
