Another intake mani. question
Old Feb 22, 2008 | 09:21 PM
Dumkid03's Avatar
Default Another intake mani. question
So i read alot of treads on the skunk2 IM....I understand that it likes a higher vtec, also I/H/E helps along with valvetrain upgrades such as cams, valves, valvesprings and retainers. now my problem i can't get a clear answer on is retuning of the ECU. if I were to buy a hondata s300....and properly tune that, would that be all the tuning necessary.
Old Feb 23, 2008 | 07:16 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Another intake mani. question (Dumkid03)
Tuned is tuned.
Old Feb 23, 2008 | 07:21 AM
jhammond_82's Avatar
Reject Papi
Default Re: Another intake mani. question (Dogginator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dogginator &raquo;</TD></TR><TR><TD CLASS="quote">Tuned is tuned.</TD></TR></TABLE> agreed. once you tune a car, you don't have to tune separately for each part on your engine. once its done, its done.
Old Feb 23, 2008 | 12:00 PM
Dumkid03's Avatar
Default Re: Another intake mani. question (jhammond_82)
I understand that. the part i don't understand is for the intake. for the butterflies? if i retune the ecu, will that take care of the ecu wanted to open up the secondaries for my oem IM? the only problem i have understanding that.
Old Feb 23, 2008 | 12:46 PM
Force1stiptopped's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dumkid03 &raquo;</TD></TR><TR><TD CLASS="quote">I understand that. the part i don't understand is for the intake. for the butterflies? if i retune the ecu, will that take care of the ecu wanted to open up the secondaries for my oem IM? the only problem i have understanding that.</TD></TR></TABLE>
If you use a skunk2 intake manifold, your car will not have the secondary butterflies... it will only have the vtec crossover wherever you decided to tune it at. The butterflies are a characteristic of the OEM GSR intake manifold
Old Feb 23, 2008 | 10:45 PM
Dumkid03's Avatar
Default Re: Another intake mani. question (Force1stiptopped)
I understand about the butterfly's, the question is about the ecu with the butterflys. is a p28 ecu needed to be shipped or will a hondata s300 take care of that issue?
Old Feb 23, 2008 | 10:46 PM
Dumkid03's Avatar
scratch that...a chipped p28 ecu**** or would a s300 take care of it
Old Feb 24, 2008 | 09:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dumkid03 &raquo;</TD></TR><TR><TD CLASS="quote">I understand about the butterfly's, the question is about the ecu with the butterflys. is a p28 ecu needed to be shipped or will a hondata s300 take care of that issue?</TD></TR></TABLE>
either of those would take care of it
Old Feb 24, 2008 | 03:27 PM
Dumkid03's Avatar
much better. sorry i couldn't explain clearly. thanks
hiboost21psi
Jun 16, 2006 06:02 AM
Bngo731
Feb 28, 2006 11:13 AM
all motor b20b
Sep 28, 2005 09:21 AM
bottlefed13
Apr 12, 2005 06:46 AM
oemDC2
Mar 26, 2004 11:57 AM
