help me decipher cel code
Old Feb 22, 2008 | 06:27 PM
Mr. Roboto's Avatar
Default help me decipher cel code
I got a 1992 eg civic cx manual, I deciphered the cel code according to the sticky and I got this funky check code. Could you help me decipher the code here's what I read.
8 short flashes, 2 long flashes, 4 short flashes, 3 long flashes repeat.
whats the code?
Modified by Mr. Roboto at 7:41 PM 2/22/2008
Old Feb 22, 2008 | 06:34 PM
BlueIntegraBoy's Avatar
Default Re: help me decipher cel code (Mr. Roboto)
Which flashes occur first?
Old Feb 22, 2008 | 06:50 PM
Mr. Roboto's Avatar
Default Re: help me decipher cel code (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">Which flashes occur first?</TD></TR></TABLE>
the fast flash, i'll explain again in full detail. I turn the key to the "on" position then of course the cel code will come on then go off, then flash on and off 8 times. then a pause (light won't come on), then it will flash long once and twice long then pause (light won't come on). then again it will flash on and off 4 times then pause (light won't come on) then flash long once, flash long twice, then flash long again and it repeats. sorry for the long type.
Old Feb 22, 2008 | 08:16 PM
EJ8tunerman's Avatar
The way your describing it, it looks like you have a code 8, 24, and 30.
Old Feb 22, 2008 | 08:43 PM
Mr. Roboto's Avatar
Default Re: help me decipher cel code (EJ8tunerman)
ok thanks I'll check them out and see
Old Feb 22, 2008 | 10:33 PM
RS2 FAB's Avatar
8 TDC - top dead centre sensor
20 Electrical load detector
4 CKP - crank position sensor
30 Automatic transmission A signal
nixcite
Sep 21, 2009 04:22 PM
karrar55
Aug 29, 2009 04:52 AM
t_dot_SiR
May 2, 2007 04:01 PM
GsrVtec
Oct 19, 2006 07:33 AM
95sihb
Nov 14, 2002 05:28 AM
