going obd1 b16 Quick ?
Old Feb 22, 2008 | 04:33 PM
Civic89stdB16's Avatar
Default going obd1 b16 Quick ?
Will the obd1 dizzy part # TD-44U Work. thanks
Old Feb 23, 2008 | 03:09 AM
Default Re: going obd1 b16 Quick ? (Civic89stdB16)
please someone
Old Feb 23, 2008 | 05:14 AM
ys1civicsi's Avatar
YES IT WILL OBD-1 DOHC B-SERIES DISTRIBUTORS ARE ALL THE SAME BUT MAY BE STAMPED DIFF. YOU MAY ALSO USE A ODB-0 ONE BUT WILL HAVE TO SWAP PLUGS. SORRY ABOUT THE CAPS
Old Feb 23, 2008 | 08:37 AM
Crx Jimmy's Avatar
Default Re: going obd1 b16 Quick ? (ys1civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ys1civicsi &raquo;</TD></TR><TR><TD CLASS="quote">YES IT WILL OBD-1 DOHC B-SERIES DISTRIBUTORS ARE ALL THE SAME BUT MAY BE STAMPED DIFF. YOU MAY ALSO USE A ODB-0 ONE BUT WILL HAVE TO SWAP PLUGS. SORRY ABOUT THE CAPS</TD></TR></TABLE>
NO a obdo dizzy will NOT work even if the plugs are swapped you need an obd1 dizzy, the only difference is if the b motor is vtec or not, the legs are aligned different, if you cut 1 leg off of the non-vtec dizzy it will bolt up to the vtec head using the other 2 bolts.
Old Feb 23, 2008 | 04:32 PM
Default Re: going obd1 b16 Quick ? (Crx Jimmy)
thanks for the help. someone can delete this now.
ivan93egreppin210
May 15, 2009 09:26 PM
thegreat0ne
Apr 15, 2007 10:19 PM
transpar_nt
Oct 1, 2005 03:36 AM
teggytegteg
Nov 19, 2004 04:25 PM
