greddy turbo kit stock b16 safe?
Old Feb 22, 2008 | 03:19 PM
99_red_si's Avatar
Default greddy turbo kit stock b16 safe?
would it be safe for me to put a greddy turbo kit on my 99 si with a stock motor about 70kmiles with hondata tuned for 8psi? daily driven. My friend told me i shouldn't do it because if i blow my motor i'm f*ck and if i turbo my car i should do it to a newer motor.
Old Feb 22, 2008 | 03:21 PM
instrument's Avatar
8lbs is safe
you could do a compression check for some added comfort.
Old Feb 22, 2008 | 04:11 PM
wearyfurball's Avatar
Default Re: greddy turbo kit stock b16 safe? (99_red_si)
putting the turbo kit should be fine as long as its tuned right. Make sure you have the right fuel upgrade and do a compression test like the other guys said.. I wouldnt use the greddy emanage use the hondata...
Old Feb 22, 2008 | 04:16 PM
Frickr's Avatar
Default Re: greddy turbo kit stock b16 safe? (wearyfurball)
8 psi i couldn't worry on a tune if you blow it then build for more boost problem solved
Old Feb 22, 2008 | 05:21 PM
Schister66's Avatar
Man U FTW
The rule of thumb for a stock block B series on pump gas is that you're safe at 300whp or less. You can make more but it takes a good setup and a good tune. If you come close to 300whp on your Greddy setup, consider yourself lucky....you'll be fine on the stock block though
Anthrolude
Sep 26, 2005 05:50 AM
CivicGSR225
Jun 17, 2004 11:54 AM
efracer
Aug 4, 2003 08:06 PM
Buzzbomb
Jul 15, 2003 12:16 PM
n*hance*ek
Dec 4, 2002 09:43 AM
