car isnt priming
i was doing errands for my mom the other day and my car shut off at a red light. i got towed back home and when i tried to start it up i listend.
my car isnt priming any gas. what could it be? electrical problem or my pump is broken?
THANKS
THANKS
check the fuel main relay, which depending on what yr your car is, if its a 6th gen(96-00) its on the passenger side in the glove box, you have to remove the glove box lid to get to it.
if its a 6th gen also check the fuse in the engine compartment listed , EM/FI its the top left one. if that pops the ecu will not let the fuel pump prime. after checking these and still nothing. remove the lower half of your rear seats. then remove the metal cover thing and disconnect the plug going to the fuel pump. put the car in the ON POS II, where everything turns on right before actually starting the car. now get a volt meter and see if theres voltage between the terminals in the connector. if there is not voltage and you checked the fuel main relay and the fuse under the hood, that means theres a short some where.
From: CAPITAL CITY Tallahassee D.S., Florida, U.S.A
check for power at the pump if it's not there i'd go after the main relay ...a quick check for that would be to turn the car to the on position CEL will appear the relay will click then it will go off and the relay will click a second time most case's if it only clicks once or not at all then the relay is bad...G/L
What year is the car??
If it's 92-95 the PGM-Fi main relay is located near the hood release cable.. should be 1 or 2 10mm bolts holding it in..
it's grey and has some japp letters on it and has one wiring harness plugged into it... tap on it a little and see if the fuel pump primes..
If that works.. you need to pull the relay.. pull the grey plastic cover off and resoldier the joints.. after so long they get dry and corrodied
Here's a link to a good DIY:
http://techauto.awardspace.com/mainrelay.html
its a 92 civic coupe. DX with a b16a swap. i tested my ecu in my friends integra and it started up fine. so its not that, im thinking its the main relay. when i check for codes it just stays as a solid cel. check engine never blinks or goes away.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_CRX_PLEASE »</TD></TR><TR><TD CLASS="quote">its a 92 civic coupe. DX with a b16a swap. i tested my ecu in my friends integra and it started up fine. so its not that, im thinking its the main relay. when i check for codes it just stays as a solid cel. check engine never blinks or goes away.</TD></TR></TABLE>
Ok well then find the main relay and tap on it with a wrench or something slightly.. and turn the key from the acc/on position and see if you can get it to kick the fuel pump on.. most likely you should be able too..
If that dont work.. then you need to pull the main relay and if your capable of soldiering.. go to the link i posted and DIY!
where is the main relay on these things? i have yet to try and figure it out i been busy :T selling the car also.
http://www.hondamarketplace.co...34208
I done told you where it was located
Near the hood release there will be a grey relay.. with a harness plugged into it.. undo the harness and there is one or two 10mm bolts holding it on..
THANKS im gonna go and try to get it started up tonight even if ie kills me ><. hopefully i get it started at least for a couple mins, i can have my brother do the soldering for me. hes my electrical man haha.
natebaur
13
Nov 17, 2010 03:04 PM
alscrx
Mar 5, 2009 03:07 PM
