Fuel pump problem
Old Jun 5, 2007 | 12:45 PM
TheAccordGuy's Avatar
Default Fuel pump problem
I notice on my 94 GSR the car is started taking longer to start and when it did start it acted as if it did not really want to sart or a laggie start. Then today all over a sudden the car will not start. I believe it's the fuel pump becuase the engine is turning over, it just seems like it getting no fuel. How hard or easy is it to remove the fuel pump in this car is the same as the civic it being in the back seat..
Old Jun 5, 2007 | 01:22 PM
ls19integra95's Avatar
Default Re: Fuel pump problem (TheAccordGuy)
on my 95 ls its under the rear seats, but it may and may bot be your fuel pump, your main relay also could have died, you also could be getting no spark... But first thing, check all your fuses because you may have just blown a fuse... my buddy had his GSR shut off on him and we thought it was the fuel pump to later find out we went straight to the more technical **** to find out it was just a fuse to his ignition...
Old Jun 5, 2007 | 02:51 PM
95 integra's Avatar
Default Re: Fuel pump problem (ls19integra95)
Mine was a fuse as well.
Old Jun 6, 2007 | 07:16 AM
Well after making this post went outside to check my fuses, but before checking I said let me try to start one more time and to my amazement the car stated right up as if nothing every happened. So my question is could this be my main relay if so how do I remove it, is it easy to replace and are they interchangeable from civics to integras.
Old Jun 6, 2007 | 07:48 PM
Default Re: (TheAccordGuy)
check all grounds that you can because one may be lose then... but the main relay isnt really that hard to replace, if i remember correctly its on your driver side under the steering column i think around your fuse block... its some where in that area but im not exactly sure the exact location because my buddy replaced his and i just saw it hanging there before he actually put it back into place... so check around some where near there
Old Jun 8, 2007 | 01:32 PM
Well I found where the main relay was I actually was just looking under my steering wheel and noticed it right next to the fuse box. There is only one 10 mm bolt holding it in place. So i took it off and went to my local junk yard and took one off a civic which is the exact same part and after putting in it started right up and has been fine since.
Jap_Spec_Imports
Sep 10, 2008 01:43 PM
whitehf
Aug 6, 2006 01:22 PM
lgn1281
Oct 14, 2005 08:26 AM
progressivedrunk
Oct 19, 2003 05:45 PM
