H22 oil leak!
Old Feb 22, 2008 | 09:23 AM
Dinan3's Avatar
Default H22 oil leak!
Hey guys, I just had an oil change done yesterday and noticed a bit later that there's oil on my driveway! I check under the hood, there's fresh oil on the bottom left side (next to the distributor and that one hose where coolant goes through, dont know wat its called). And well, I check my oil level, its quite above the max point. Before the oil change, there were NO leaks, and oil level was at the max point, and my motor doesnt seem to burn ANY oil as I've never had to top it off... So what could it be? Is it because the oil level is too high? Should I return to the shop and have it drain a bit out? Wat can having "too" much oil in the car do?
Help PLease!! lol
Thanks guys,
Mike.
Old Feb 22, 2008 | 02:35 PM
speedracer9k's Avatar
Default Re: H22 oil leak! (Dinan3)
sounds like your distributor o-ring went out. take it back to the shop and have them deal with it. tell them that nothing was leaking before you came in.
Inextricabledrvr
May 3, 2008 09:42 AM
AZNMOB
Jan 25, 2007 06:13 PM
EKcivic1230
May 31, 2005 06:23 PM
todaspecsi
46
Apr 29, 2004 05:08 PM
Chayse
Oct 1, 2001 05:47 AM
