Is this tranny the same?
Old Feb 21, 2008 | 07:16 PM
Dressed Accordingly's Avatar
Default Is this tranny the same?
Is an automatic transmission exactly the same out of a '91 accord as the one in a '94 accord? I know the '91 will fit directly on my '94 but is there any difference?
Old Feb 21, 2008 | 07:28 PM
TheMuffinMan's Avatar
He knows where you live!
They're not the exact same but they're swappable.
Old Feb 21, 2008 | 07:40 PM
what is different? just the gear ratios?
Old Feb 21, 2008 | 07:45 PM
I believe it's just the gear ratios.
I would imagine theres a bit of different material in it as well but overall they're similar.
Old Feb 21, 2008 | 08:16 PM
Thanks
Old Mar 2, 2008 | 12:37 PM
Default Re: (Dressed Accordingly)
So could'nt i just chip & tune the ECU to use those long gears for my advantage AND not fall out of vtec?
BTW Thanks for the help MUFF
Old Mar 2, 2008 | 03:29 PM
street_accord94's Avatar
if you are still using a sohc engine you shouldnt fall out of vtec...since it actuates between 2300 and 3200 rpm.
Old Mar 2, 2008 | 04:02 PM
Default Re: (street_accord94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_accord94 &raquo;</TD></TR><TR><TD CLASS="quote">if you are still using a sohc engine you shouldnt fall out of vtec...since it actuates between 2300 and 3200 rpm.</TD></TR></TABLE>
Yeah if you stay with the F series and don't go to the H you shouldn't drop out of vtec.
If you use a F tranny on an H motor it'll drop out because they're longer gears.
Old Mar 2, 2008 | 04:18 PM
bseriescrxsi's Avatar
Default Re: (TheMuffinMan)
the only one thing i can think you will have to do it on the 90-93 the tranny has colling lines in the front and back where as the f22b(94) only has cooling lines on the front so you may beed to loop off the back so the cooling system on it works
Old Mar 2, 2008 | 05:54 PM
No what im saying is i AM doing the H swap but wanna use my F auto trans cant i bypass the falling out of vtech by chipping and tuning the ecu to do so?
Old Mar 2, 2008 | 06:00 PM
v4lu3s's Avatar
RTFM
chipping does not fix or change longer gears. it is a physical limitation not a tuning one.
Old Mar 2, 2008 | 06:36 PM
OH they told me chip & tuning it would be better than changing trans because they are longer thats better and with the ecu tune it can shift whenever i want it to so it doesnt fall out of vtec.......
Old Mar 2, 2008 | 07:46 PM
i wouldn't trust whoever is feeding you that info.
Old Mar 2, 2008 | 07:49 PM
Gears are gears.
Can't do much to change them.
Once you get up in RPM's and hit VTEC with the H series, and it shifts (with the F tranny) you'll drop too low to stay in VTEC.
They *may* mean set a static point for VTEC to hit and just set it incredibly low. But I don't think that's a good idea.
Old Mar 2, 2008 | 08:08 PM
yeah it is definitely the hack way of trying to get around the stock transmission. i would just spring for a jdm h22 auto with tcu and call it a day.
Old Mar 3, 2008 | 09:41 AM
DoC-JoneS's Avatar
i agree. as far as modifying the tranny or trying to adjust shift points i'd leave that well enough alone. the honda automatics are well designed. i'd try and find a jdm h22/w TCU that will be the best combo for your car.
fminajr
Transmission & Drivetrain
Jun 11, 2016 07:04 PM
endless_sugar
Sep 29, 2009 04:32 AM
helpmeplease
Mar 27, 2008 04:47 PM
tpeck
Jul 28, 2007 05:43 AM
Staats0778
Jan 12, 2005 06:01 AM
