Car won't start! --94 Civic EX-- Throwing CELs 17 & 41
Old Feb 21, 2008 | 07:09 PM
8point6's Avatar
Default Car won't start! --94 Civic EX-- Throwing CELs 17 & 41
Pretty sure it's getting fuel and spark now. Engine cranks, but won't start:
I first checked for spark and found out I had a weak coil, so I replaced it with the dealership's coil for $125 . Then I replaced the plugs, just in case.
Still wouldn't start.
Checked for fuel pressure at the rail, and it was okay, so I'm stuck.
My check engine lamp has been on for a couple weeks. I've ignored it until now, but the car ran fine until now. Could either of these two cause the car to NOT start?
CEL 17 - VSS - speed sensor
CEL 41 - Primary oxygen sensor heater
Thanks
Modified by 8point6 at 8:36 PM 2/21/2008
Old Feb 22, 2008 | 10:25 AM
8point6's Avatar
Default Re: Car won't start! --94 Civic EX-- Throwing CELs 17 & 41 (8point6)
up!
Old Feb 22, 2008 | 10:52 AM
robbberto's Avatar
the vss sensor code most likely came on because the vehicle cut off while driving and will not keep your car from starting, and the o2 code will not keep a car from starting. O2 sensors will only couse a rich or lean condition and they only really operate after the vehicle reaches close loop. Check your main relay by placing a test light at the plug for the fuel pump and see if it lights up when you turn the ignition switch on. or an easier way is to roll up your windows and listen for your fuel pump when the ignition switch is turned on. you should hear a 2 to 3 second humming sound everytime you turn the ignition switch to the on position.
Old Feb 22, 2008 | 04:53 PM
8point6's Avatar
Default Re: Car won't start! --94 Civic EX-- Throwing CELs 17 & 41 (robbberto)
I've actually got fuel pressure; I can hear the pump and have also cracked the nut on the fuel rail to find pressure there, too.
Old Feb 23, 2008 | 03:18 AM
8point6's Avatar
bump
Old Feb 23, 2008 | 03:42 PM
8point6's Avatar
ideas?
Old Apr 10, 2008 | 09:46 PM
8point6's Avatar
up
Old Apr 10, 2008 | 09:52 PM
Former User's Avatar
Do you have bright spark at all four plugs? Is the ground wire on the thermostat housing firmly attached? Has the timing belt slipped a few teeth?
Old Apr 10, 2008 | 10:05 PM
8point6's Avatar
Default Re: Car won't start! --94 Civic EX-- Throwing CELs 17 & 41 (RonJ@HT)
The spark seems normal. I haven't checked the t-belt. I didn't realize that it could've slipped.
Old Apr 10, 2008 | 10:14 PM
Whether or not the timing belt has slipped, you should also check the compression in the cylinders.
xxzombierot
Mar 10, 2013 09:53 PM
pdetering186
Dec 27, 2012 10:06 AM
buzlink
11
Feb 28, 2010 11:36 AM
jdmallmotorhatch
Aug 15, 2008 11:03 PM
OogalyDoogaly
May 5, 2008 07:26 PM
