arp headstud help
ok guys i did a ls/vtec but i think i got the wrong headstuds on ebay they said ls/vtec & b20/vtec product num 208-4306 but we put them on & now theres oil in my 1 & 3 cyl could the headstuds be the problem help me out guy thanxs
headgaskest is new but i also wus thinking hg so i bought a new 1 but i dont wanna put it on if it do the same thing i wanna find out if b20 headstuds will work on b18a with a b16 head its pissin me of haveing at home just sittin there
208-4303 is the part number that you need. It is the same number for a GSR. these are the head studs i am currently using in my setup. Maybe you didnt torque the head to spec.
I think coolant would be in the oil if the headgasket was upside down,it is not as uncommon as people think i had done it with my cometic gasket tho.
lol honest mistake
Modified by lluks_844 at 2:03 PM 2/21/2008
lol honest mistakeModified by lluks_844 at 2:03 PM 2/21/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyguy »</TD></TR><TR><TD CLASS="quote">i am under impression that all b series headsutds are the same but not sure about b20</TD></TR></TABLE> 208-4202 - Ls
208-4303 - gsr
208-4306 - b20 w/b16 head
208-4301 - b16a
208-4303 - gsr
208-4301 - b16a
so basically i cant use the studs i have is ther anyway possible they could be used im just tight on money right and no therse no coolant in my oil just oil burning like hell in num 1 & 3 cyl num 3 has the most dont know why here are sum pics of the num 1 & 3 cyl exhaust ports
number1
number3
number1
number3
well we used the 1 that came wit the lsv kit i have a new honda 1 just not tryin to mess it up if its the studs thats giving me prblems and yes we pluged the oil hole in the head wit the skrew that came with the kit its my first build n relly dont know wtf is up it sounds good and everything but its burning oil like hell should i just change the headgasket to see if it stops
Make sure that you torque your studs down correctly, easiest way to start troubleshooting in this case. They need to be torqued in a specific order as well. If you search around honda-tech.com, you're bound to find them. I did when I needed them.
tazzsi84
24
Mar 7, 2009 05:10 PM
