intake + header + which exhaust
Anyone know the hp or have dyno charts for Injen CAI + DCRH and any of the following : Skunk2 70mm, Greddy Evo2 + Sp2 exhaust, or HKS?
I wanna basically know how much these exhausts help with the intake and header. I heard people have bogs/hesitation with only intake and exhaust relieved it of that problem so i was thinkin about getting an exhaust. Does anyone know the HP boots for each? Cause if it's not much I'd probably go with greddy so i can drive in peace, but if HKS or Skunk is that big then i'd probably go with them. I heard that exhausts didn't really help much but with intake and header it mite help more than what i heard.
Intake and race header will make the biggest difference. The exhaust system on these cars is very restrictive so eliminating the Catalytic Converter really frees up a good amount of power. The exhaust won't make a much bigger difference after that.
yea, but all you need to do is take it to an exhaust shop and tell them to pop the cat back on after the header...after emissions, go back and replace the cat again, but with a test pipe this time...same diameter and you will be fine...i have the same set-up actually, and that is my exact plan..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zavala07si »</TD></TR><TR><TD CLASS="quote">yea, but all you need to do is take it to an exhaust shop and tell them to pop the cat back on after the header...after emissions, go back and replace the cat again, but with a test pipe this time...same diameter and you will be fine...i have the same set-up actually, and that is my exact plan..</TD></TR></TABLE>
Or just pay a shop to "pass" you.
alfaaay
Aug 8, 2003 12:46 AM
