GSR cam questions
Old Feb 19, 2008 | 09:35 PM
See Are X's Avatar
Default GSR cam questions
I'm thinking about swapping my b16 cams for some gsr's and have a couple questions...
1) Are there any differences between years(94-01)?
2) Are all b-series cam gears the same? Would the GSR cam gears work with a B16 head?
3) Would it be possible to change out cames without touching the timing belt tensioner? By just removing the cam caps and swapping out the cams?
Old Feb 19, 2008 | 10:45 PM
inspyral's Avatar
1) Not that I'm aware of.
2) B series cam gears are the same.
3) This is possible if you trim the inside upper timing cover, or have it removed completely. There's a cam swap video on the Evans Tuning site that covers this. It's also only recommended if your tension is good to begin with.
Old Feb 20, 2008 | 08:47 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: (inspyral)
only thing about that vid that i disagree with is not lashing the valves.
but it is a good how to.
mouab18c1
32
Aug 3, 2011 06:00 PM
killacam661
Feb 11, 2010 09:07 PM
JDM00SI
Feb 11, 2005 10:34 AM
MaxSterling
Jul 11, 2003 04:16 PM
