Need Help on Fuel PRessure
Old Feb 19, 2008 | 09:19 PM
eagleclawracing's Avatar
Default Need Help on Fuel PRessure
I have An eg with H22 need to Find out what Fuel pressure Im Runing i have the stock reg but with walbro on it thanks
Old Feb 19, 2008 | 09:36 PM
Hawkze_2.3's Avatar
Default Re: Need Help on Fuel PRessure (eagleclawracing)
How can someone check it over the internet?
Obviously you need a fuel pressure gauge.
Old Feb 19, 2008 | 11:45 PM
Default Re: Need Help on Fuel PRessure (Hawkze_2.3)
well if i had one i wouldnt ask...
Old Feb 20, 2008 | 04:47 AM
98vtec's Avatar
moderator emeritus
either buy a gauge or buy the pressure tester from autozone
Old Feb 20, 2008 | 05:38 AM
boostedh22lude1's Avatar
Default Re: Need Help on Fuel PRessure (98vtec)
you still have the same fuel pressure with a walbro unless you changed the regulator, the fpr is what regulates the pressure not the pump
Old Feb 20, 2008 | 09:10 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eagleclawracing &raquo;</TD></TR><TR><TD CLASS="quote">well if i had one i wouldnt ask...</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by from above &raquo;</TD></TR><TR><TD CLASS="quote">
Obviously you need a fuel pressure gauge.</TD></TR></TABLE>
Old Feb 20, 2008 | 11:18 AM
lude98SH's Avatar
this is the honda spec:
With vacuum line off FPR
47 psi
With vacuum line reconnected
37psi
01_ITR
Jul 15, 2008 09:26 PM
AZNracerx1989
Jul 13, 2006 08:25 AM
Stoich
Jul 26, 2005 12:27 PM
Muckman
Dec 6, 2003 01:40 PM
SOFLSOL
Sep 17, 2003 03:18 AM
