wiring nightmares....please help me
ok. so last month i noticed that my drivers door lock switch would not work. it would unlock the door but not lock it. Not even a budge as if it wasnt getting power.
two weeks ago i was going through the bridge i rolled my window down. i rolled it up and things were fine. later that day i tried to roll it down and the 2 drivers switches would not work. The drivers control for the drivers window and the passenger window. The passenger window control does work though. Also the drivers control for the child window lock does work too which is odd.
first think i did was replace the lock switch and the drivers window switches. no luck..
i then checked the fuses and all were fine.....
i checked for broken wires... couldnt find any in the door or visibly....
i replaced the small little window relay and still doesnt work....
The thing that baffles me is the fact that my VIPER auto door locks still work. how could they work if i cant use the switch from inside the car but i can use the keypad remote. i replaced the switches and everything.
my question is... what else could be wrong. im lost here and know only a little about wiring.
im at a loss here. thanks
chris4x4
13
May 8, 2011 10:39 AM
