greddy emange ultimate
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">the fic dosnt work properly on hondas...
says who and why not? ive seen users on other forums use them np on NA applications...
if you use it with just the crank sensor it works fine, when you hook up the cam and crank sensors then mess with timing the car does all sorts of messed up stuff.
thats all on obd2 stuff where we wanted them to still pass inspection.
there is a new part number for the fic for hondas, ours are supposedly modified to the same specs and still dont work properly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">if you use it with just the crank sensor it works fine, when you hook up the cam and crank sensors then mess with timing the car does all sorts of messed up stuff.
there is a new part number for the fic for hondas, ours are supposedly modified to the same specs and still dont work properly</TD></TR></TABLE>
interesting, thanks for the info...
