UPDATE: Custom catch can setup ;)
Old Feb 20, 2008 | 08:02 PM
GSROWNSU's Avatar
Default UPDATE: Custom catch can setup ;)
Turbo install is coming along. Wastgate fits perfectly. My buddy is going to school for cnc so he made me a custom bracket for my catch can. The can is from B&R Fittings. Fittings are AN-12 push lock with Aeromotive Push Lock hose. Very strong stuff. I love how it turned out...very clean look. Lemme know what u guys think.
Old Feb 21, 2008 | 09:34 AM
GSROWNSU's Avatar
bump...no one wants to see how my build is coming along?? lol
Old Feb 21, 2008 | 09:40 AM
agrn93ls's Avatar
Default Re: (GSROWNSU)
I noticed multiple things in your engine bay that looks like you take extra steps to keep things cleanly routed and simple
Old Feb 21, 2008 | 10:17 AM
boostedh22lude1's Avatar
Default Re: (agrn93ls)
looks great
Old Feb 21, 2008 | 02:24 PM
GSROWNSU's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by agrn93ls &raquo;</TD></TR><TR><TD CLASS="quote">I noticed multiple things in your engine bay that looks like you take extra steps to keep things cleanly routed and simple
Thanks man! That's what im going for. When i started this build i wanted it to be as clean as i could possibly make it and i want everything to look like it's "meant to be there" the bracket for the catch can actually shines more than the can itself haha.
Old Feb 21, 2008 | 03:32 PM
JaredKaragen's Avatar
just a heads up; but for all of the setups I have seen with the breathers in the front of the valvecover, especially with the can lower than the lines;
I have noticed it picking up more oil than the ideal routing; and sometimes excessive amounts. This is because the motor is angled slightly to the front, and the oil tends to get sprayed right into the tubes from the oil jets in the head... But not always.
Looks good!
Old Feb 21, 2008 | 05:52 PM
GSROWNSU's Avatar
even with the valve cover baffles still in the valve cover? Even if the oil jets squirt the valve cover wouldn't it just bounce off the baffles and not go into the catch can lines? thanks for the heads up tho and the comments guys!
Old Feb 21, 2008 | 06:15 PM
jdmef-9's Avatar
ive been running this set-up in my car for well over a year making a good amount of power and never noticed anything................
Old Feb 21, 2008 | 07:15 PM
welfarepc's Avatar
curious why you have a breather filter on the back of the VC instead of another line to the catch can?
clean
Old Feb 22, 2008 | 05:26 AM
agrn93ls's Avatar
Default Re: (welfarepc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by welfarepc &raquo;</TD></TR><TR><TD CLASS="quote">curious why you have a breather filter on the back of the VC instead of another line to the catch can?
clean</TD></TR></TABLE>
wouldnt matter in his case, he is only running "breather" tubes, he is not running a vacuum setup, that is only a breather setup, so him running a filter on a pipe versus hooking a hose to the pipe then to a filter is all the same.
basically his can is the same exact thing as the filter on the valve cover just much larger and capable of containing oil since it has a "resevoir"
Old Feb 22, 2008 | 05:28 AM
agrn93ls's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSROWNSU &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks man! That's what im going for. When i started this build i wanted it to be as clean as i could possibly make it and i want everything to look like it's "meant to be there" the bracket for the catch can actually shines more than the can itself haha. </TD></TR></TABLE>
the invisible radiator is sweet!
Old Feb 22, 2008 | 03:40 PM
GSROWNSU's Avatar
yea you know you like it lol. I put the radiator in with my stock fan and it actually fits perfect. Nothing comes close so it will really nice to keep a full core radiator in my car.
Old Feb 22, 2008 | 04:17 PM
Tippyman's Avatar
What are you using all the vacuum lines coming off of the log for? I can only think of three things I will need on mine...
Old Feb 22, 2008 | 04:22 PM
GSROWNSU's Avatar
1. bov
2. wastegate
3. boost controller (solenoid)
4. boost controller (for the pressure in nipple on my actual controller)
* i have a t fitting for my boost gauge off the fuel pressure regulator
rogueeg6
Jul 19, 2011 05:45 PM
Froth
Jul 16, 2007 02:00 PM
*Boostwerks*
Jul 1, 2007 08:23 PM
TurboJesse
Oct 11, 2006 09:27 PM
JDM_JON
Jan 22, 2004 07:06 AM
