greddy emange ultimate
Old Feb 19, 2008 | 07:48 PM
Totall Insane's Avatar
Default greddy emange ultimate
Is the greddy emanage ultimate a good engine management for a mild street turbo set up on a b16?
Old Feb 19, 2008 | 08:45 PM
blinx9900's Avatar
Default Re: greddy emange ultimate (Totall Insane)
yes but its usually reserved for people with less options, why not go with AEM FIC? or even neptune RTP?
Old Feb 20, 2008 | 03:01 AM
JDogg's Avatar
Default Re: greddy emange ultimate (blinx9900)
the fic dosnt work properly on hondas...
emanage works, but a chipped ecu is a much better option.
Old Feb 20, 2008 | 03:08 AM
blinx9900's Avatar
Default Re: greddy emange ultimate (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">the fic dosnt work properly on hondas...
says who and why not? ive seen users on other forums use them np on NA applications...
Old Feb 20, 2008 | 08:43 AM
JDogg's Avatar
if you use it with just the crank sensor it works fine, when you hook up the cam and crank sensors then mess with timing the car does all sorts of messed up stuff.
thats all on obd2 stuff where we wanted them to still pass inspection.
there is a new part number for the fic for hondas, ours are supposedly modified to the same specs and still dont work properly
Old Feb 22, 2008 | 03:32 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg &raquo;</TD></TR><TR><TD CLASS="quote">if you use it with just the crank sensor it works fine, when you hook up the cam and crank sensors then mess with timing the car does all sorts of messed up stuff.
there is a new part number for the fic for hondas, ours are supposedly modified to the same specs and still dont work properly</TD></TR></TABLE>
interesting, thanks for the info...
gsrturboEK
Sep 12, 2008 09:35 PM
avoturbo
Aug 21, 2007 09:11 AM
spooniq
Honda S2000
Mar 30, 2006 08:15 PM
aznwash3wboi
Nov 8, 2005 11:00 PM
98cwitr
Feb 19, 2004 11:12 AM
