Converting an ECU from Auto to Manuel
Old Feb 19, 2008 | 07:40 PM
JONESER's Avatar
Default Converting an ECU from Auto to Manuel
I done some reading in the FAQ's section and read about converting ECU's from auto to manuel. The ECU that's in my car ('93 Civic hatch with B18a1 swap, auto to manuel swap)is a P75. It is the auto version(A51). Does anyone know the details on doing the conversion to this ECU?
If not, what would be the best ECU to replace it with?
THANKS!
Old Feb 19, 2008 | 07:46 PM
jasony0630's Avatar
76.26.106.124
why not just get the proper ecu??
unless it is WAY too expensive....
but yes, i have seen a auto - manual ecu conversion walkthrough on h-t somewhere...just look around im sure youll find it.
Old Feb 19, 2008 | 07:53 PM
JONESER's Avatar
Default Re: (jasony0630)
Well, this way would be free... I've read about doing the conversion, but not on my specific ECU, P75. I don't know if the boards are the same with one's that were described. That's what I'm trying to figure out.
If there isn't a way to do the conversion on mine, I would like to know what the best replacement would be. For best performance & gas mileage.
Old Feb 19, 2008 | 08:00 PM
eg8tuner's Avatar
i got a chipped p28 for my vtec swap last yaer off ebay for like 250 and it came with like 5 pre mapped chips. this is an easy way to go about solving your issue because a regular ecu was between 100-200. just check ebay for your ecu. the cost is worth the saved headache of solidering.
Old Feb 19, 2008 | 08:01 PM
ke98248's Avatar
Default Re: (JONESER)
Yeah, only if you don't fuck it up -- that is -- switching it over.
Old Feb 19, 2008 | 09:04 PM
Echo7847's Avatar
Default Re: (ke98248)
It involves adding/removing a jumper wire @ points RP17&RP18 on the board itself.
Contact Mtber here on h-t he is local to you and I and does ecu's all day long.
Old Feb 20, 2008 | 08:04 AM
Relic1's Avatar
if you can solder, remove RP17 & RP18, jumper across RP18. (unless it's a JDM ECU)
If you can't solder then hit up mtber to do it. (local is always good) Should take a few minutes tops.
Old Feb 22, 2008 | 03:23 PM
JONESER's Avatar
Default Re: (Relic1)
When you say jumper rp18, do you mean just solder a wire where the resistor was on rp18 and just leave rp17 without a resistor?
Old Feb 22, 2008 | 03:37 PM
HAMOTORSPORTS's Avatar
yes, rp18 just needs to be "jumped" , and rp 17 simply cut. You will want to socket the ecu and chip to run a manual program though.
Old Feb 22, 2008 | 03:38 PM
THC07's Avatar
yea thats what he means.
Old Feb 22, 2008 | 03:49 PM
JONESER's Avatar
Default Re: (HAMOTORSPORTSUSA)
HUH? Socket? I'm new to Honda's and I'm not sure of all the terminology.
I just want this damn car to run & get me good gas mileage for work!
THANKS!
Old Feb 22, 2008 | 07:10 PM
Relic1's Avatar
no need to chip the ECU, it will run fine on the stock maps, not quite identical to a manual ECU, but close enough.
Old Feb 22, 2008 | 07:12 PM
id3379's Avatar
send it to katman, he'll repogram it for $50
--> http://ecu.ff-squad.com/
Modified by id3379 at 8:22 PM 2/22/2008
Old Feb 22, 2008 | 07:40 PM
serio_ENDLESS's Avatar
i just did a auto p28 all i did was take out the resistor off rp17 and put i a jumper wire from rp18 to rp17
Old Jun 14, 2008 | 11:52 PM
sorullo's Avatar
ok i have the same problem but if i do it, will my car pass the emittion test?? thoo, i live in california!!
mitsubishiv5
Mar 24, 2009 01:26 PM
atleast-3
Jun 5, 2007 01:07 PM
KaoSyN
Dec 15, 2005 11:03 PM
p10hlm
Jan 8, 2003 08:21 PM
wronghand
Jun 6, 2002 04:53 PM
