civic
ive reading a couple of the starting problems fom other people on their civics. None of the post help me figure out my problem. I have a 97 civic which was starting fine until one cold night here in wisconsin. I went ahead and bought a new starter thinking that was the problem. Change the starter that same afternoon and the car turn on fine. A couple of days later the same problem, i turned on by pushing it the car turned on and i took it to honda dealer to check it out cuz it was a lil to cold and i dont have a garage. they said that some of the wires were loose and they took care of that. The car did fine until it did again. Since its been sitting in the back of my house. The car does have a remote starter if it does help.
Please let me know what you guys think and i would really appreciated.
i grabbed popcorn and a soda to read that touching story from wisconsin.
jkjk
is it like the battery has no power and wont turn over or what?? does it turn over at all? it sounds to me like maybe a bad alternator thats not charging if it dies after you drive it each time.
jkjkis it like the battery has no power and wont turn over or what?? does it turn over at all? it sounds to me like maybe a bad alternator thats not charging if it dies after you drive it each time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egSLEEPER »</TD></TR><TR><TD CLASS="quote">i grabbed popcorn and a soda to read that touching story from wisconsin.
jkjk
is it like the battery has no power and wont turn over or what?? does it turn over at all? it sounds to me like maybe a bad alternator thats not charging if it dies after you drive it each time.</TD></TR></TABLE>
heheh
change the battery change the alterantor try that.
jkjkis it like the battery has no power and wont turn over or what?? does it turn over at all? it sounds to me like maybe a bad alternator thats not charging if it dies after you drive it each time.</TD></TR></TABLE>
heheh
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sirll »</TD></TR><TR><TD CLASS="quote">
heheh
change the battery change the alterantor try that.</TD></TR></TABLE>
Great idea. Throw parts at it until you find the problem. YAY internet mechanic!!!
heheh
Do you have good power to everything else? My starter seemed to just up & quit on me too, out of nowhere. It wasn't the starter. Take a piece of wire & jump it from the + on the battery and the small(Black/white)wire on the starter. If that starts it (make sure the key is in the on position), you have to run a new wire from your ignition to the starter. Get under your column and find the black/white wire at the harness. See if your getting 12 volts when you turn the key(like your starting it). If you are, just run a new wire from the harness all the way to the starter. Worked for me and I haven't had any starting problems since.
Good Luck!
Good Luck!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedooo »</TD></TR><TR><TD CLASS="quote">most likely the alternator</TD></TR></TABLE>
civic-jud
Honda Civic (2016 - Current)
Mar 18, 2019 07:15 AM
professorman
Mar 18, 2013 10:44 AM
mkinpwrat12g's
Aug 24, 2005 05:50 PM
