integra LS turbo question-s
I have a 2000 integra with a turbo running only 8lbs of boost. I wanted to know how much boost on a stock motor I can run before I start blowing sh-t up and stuff like that. I have heard 12lbs if the vehicle is tuned correctly and 7-8lbs if its just a bolt on turbo. ALso that if I plan to run more boost, that a thicker head gasket will need to be used, which I fully understand. So any comments would be appreciated. I'd love to have the option to get a-movin if I so feel the need to during the warmer months of the year!
[Q<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byaaah! »</TD></TR><TR><TD CLASS="quote">Lbs. of boost have nothing to do with anything</TD></TR></TABLE>
By saying this, he meant that engines blow up because of horsepower not pounds of boost. Do you know how much power you have now? also, what are you aiming for?
I have no idea what I have actually. I wish I did, I might have to take it in to get tested, otherwise, I'm not sure what to look for but something VERY comfortable
well as far as i was told... i could push a bar, which is 15psi.. stock internals with a t3/t04.. of course thats with a stand alone.. bigger injectors.. i was told that the biggest weakness in b18's are the rods.. i plan on doing wiseco pistons, eagle rods, head studs, 750cc injectors, hondata s300, fuel pump, with a t3/t04.. my goal is around 300whp which i was told i would be able to run safely... i would do a compression test on ur car, and if the numbers a decent, im sure u can push 8lbs safely with stock internals.. highly recommend hondata, for that could be the main difference between blowing ur motor or running safely..
https://honda-tech.com/zeroforum/16
Again, boost doesn't mean anything...either does telling us you have a "T3/T4" because there are about 10,000 turbos in the category
