IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP?
Old Feb 19, 2008 | 03:25 PM
jdmgeorgeeg6's Avatar
Default IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP?
IM GOING TO TURBO MY LS, EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP IM ONLY PLANNING ON BOOSTING LIKE 6 POUNDS
Old Feb 19, 2008 | 03:35 PM
VtecnTurbo's Avatar
Default Re: IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP? (jdmgeorgeeg6)
you can if you get engine management. Ex: Crome Neptune
but you should get some 550cc injectors. Same price as the 440cc and leaves you room to grow & your motor will be safe if you blow a vac line or get a boost spike.
You will love boost, i know i do
good luck
Old Feb 19, 2008 | 04:05 PM
iBear's Avatar
Default Re: IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP? (VtecnTurbo)
You can use your stock injectors and fuel pump.
But like he said up there, it wouldn't hurt to upgrade those parts.
Old Feb 19, 2008 | 04:13 PM
VTECth1s's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmgeorgeeg6 &raquo;</TD></TR><TR><TD CLASS="quote">IM GOING TO TURBO MY LS, EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP IM ONLY PLANNING ON BOOSTING LIKE 6 POUNDS </TD></TR></TABLE>
YES YOU CAN!!!...unclick your caps. And it depends on the turbo you plan on using. 6lbs on a mitsubishi turbo, or 6lbs on gt35 turbo. Hell of a difference between the two.
Get an ems, and get it tuned!
Eric Kamphey
Mar 4, 2017 03:35 PM
93da9kid
Jan 30, 2011 07:08 AM
ahmongboi
Mar 27, 2010 06:10 AM
xxrjxx
Apr 5, 2008 06:45 PM
mrdeadman
Jul 15, 2005 10:41 AM
