IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP?
IM GOING TO TURBO MY LS, EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP IM ONLY PLANNING ON BOOSTING LIKE 6 POUNDS
Re: IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP? (jdmgeorgeeg6)
you can if you get engine management. Ex: Crome Neptune
but you should get some 550cc injectors. Same price as the 440cc and leaves you room to grow & your motor will be safe if you blow a vac line or get a boost spike.
You will love boost, i know i do
good luck
good luck
Re: IM GOING TO TURBO MY LS EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP? (VtecnTurbo)
You can use your stock injectors and fuel pump.
But like he said up there, it wouldn't hurt to upgrade those parts.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmgeorgeeg6 »</TD></TR><TR><TD CLASS="quote">IM GOING TO TURBO MY LS, EK CAN I USE MY STOCK INJECTORS AND FUEL PUMP IM ONLY PLANNING ON BOOSTING LIKE 6 POUNDS </TD></TR></TABLE>
YES YOU CAN!!!...unclick your caps. And it depends on the turbo you plan on using. 6lbs on a mitsubishi turbo, or 6lbs on gt35 turbo. Hell of a difference between the two.
Get an ems, and get it tuned!
