Car shut off while driving...need help asap!!!!
Old Feb 19, 2008 | 03:05 PM
Th3savinday's Avatar
Default Car shut off while driving...need help asap!!!!
heey whats up guys...so basically i was leaving my work and my car start stuttering and finally just floored it to give it more gas...after about a couple seconds of that the car just shut off...i pulled over and tried cranking it...i have to check it out tomorrow...but recently i changed the cap and rotor and the ignition coil...
earlier that day i wasn't able to start it...i checked the ignition coil and checked the cap and rotor...changed the battery and after turning it over for a good minute or two it started up...but was stuttering...it shut off a couple times on its own, and as i tried starting it up again i gave it more gas and i felt the car shaking as i was giving gas...i finally got it idling fine after just laying on the gas for a little while...i let it warm up before i drove...test drove it and noticed that as i was driving the tach kinda went crazy for a couple seconds...after a little while it started working fine and had no problems.
what do you guys think?? could it be TPS? IAC?...i changed fuel pressure aroudn to see if that made a differnce and nothing...im going to check ignition to see if im getting spark on all 4 cylinders...if you have any ideas of what i should be checking out please give me suggestions...that would be awsome...my car is not near my house, so its hard getting back and forth...thanks guy in advanced...i need the help!!!!!
Old Feb 19, 2008 | 03:09 PM
matmcg's Avatar
Default Re: Car shut off while driving...need help asap!!!! (Th3savinday)
I had the same problem when i got my car to start the engine was shaking like crazy
I changed the whole dizzy and still nothing
sometimes it doesnt even turn on
When i drove it it shut off
Sometimes it kind of starts and i press the gas to keep the engine idling and it seems like no gas is getting in
Old Feb 19, 2008 | 03:10 PM
matmcg's Avatar
i think that it is my spark plugs that are ruined most likely in my first and second cylinder thats spark plugs not the wires
Default Re: Car shut off while driving...need help asap!!!! (matmcg)
yeah its a pain in the *** cause this is my DD
Old Feb 19, 2008 | 03:14 PM
matmcg's Avatar
Same with me.
How often can you get it to start?
Old Feb 19, 2008 | 03:19 PM
Default Re: (matmcg)
this just happened to me all today...it has been stuttering randomly a long time ago...but all this happened today
Old Feb 19, 2008 | 03:25 PM
SkaiWu's Avatar
what if the engine is too old oO and ***** just bad?
i dunno
bump for help cause
Dogginator's Avatar
Daisy... Daisy...
What year is the car? Is the ECU stock? Do you have any CELs?
Old Feb 19, 2008 | 09:52 PM
Default Re: Car shut off while driving...need help asap!!!! (Dogginator)
the car is a 1995 integra ls...just built last year and has been running fine until now...the ECU is hondata s100...set up for a vtec....as for CELs...im not too sure what that means...maybe you can help me out on that one..haha
if you mean codes...then no its not
thanks again for the fast responses
motor = b18b1 bored 81.5
stroker kit
crower cams
intake, and all that good stuff
94-integra-ls
Oct 27, 2009 10:14 AM
pcguy760
Oct 26, 2008 06:03 AM
SIK IN DA HED
Nov 12, 2002 09:36 PM
04accordV6
Jul 31, 2002 11:53 PM
accordfreak
Mar 12, 2002 12:56 PM
