Where to get Manifold Studs? (Revhard Style Manifold to Turbo)
Old Feb 19, 2008 | 01:40 AM
integlspwr2k's Avatar
Default Where to get Manifold Studs? (Revhard Style Manifold to Turbo)
I am currently looking for those 4 manifold studs that you use when you mount the turbo to a rev hard style manifold
Honda header studs are too small for them so I needed something bigger.
Anyone know the measurements of what i need and where I can get them.
Thanks In advance..
Old Feb 19, 2008 | 02:41 AM
inspyral's Avatar
They should be 10x1.5
http://www.atpturbo.com/Mercha...e=FST
Old Feb 19, 2008 | 02:49 AM
Default Re: (inspyral)
is it 10x1.5 or 10x1.25 ?
Old Feb 19, 2008 | 06:11 AM
Luserkid's Avatar
Default Re: (integlspwr2k)
1.25. I believe thats a typo or not for Hondas.
Edit: My bad, i thought you meant for in the head to hold the manifold, not for the manifold to hold the turbo. If thats the case it all depends on who made the manifold and what they wanted to use. You could always grab a tap and see which goes in smoother, 1.25 or 1.5
Modified by Luserkid at 4:33 PM 2/19/2008
Old Feb 19, 2008 | 10:08 AM
Default Re: (Luserkid)
so 1.25 is for hondas? or 1.5?
haha im lost.
Old Feb 19, 2008 | 03:13 PM
inspyral's Avatar
Hmm, just checked my notes, and it looks like Drag, Rev-Hard, and Inline Pro manifold to turbo threads are 10x1.25(per Stan). I'm using the studs above from ATP with my BLOX manifold, and they work fine, so I assume BLOX are 10x1.5. Sorry for the confusion.
Old Feb 19, 2008 | 03:56 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by inspyral &raquo;</TD></TR><TR><TD CLASS="quote">Hmm, just checked my notes, and it looks like Drag, Rev-Hard, and Inline Pro manifold to turbo threads are 10x1.25(per Stan). I'm using the studs above from ATP with my BLOX manifold, and they work fine, so I assume BLOX are 10x1.5. Sorry for the confusion.</TD></TR></TABLE>
hell i'll get 4 of each. i mean its pretty cheap.
Old Feb 19, 2008 | 04:09 PM
project dc2's Avatar
blox are 10X1.5
revhard are 10X1.25
Old Feb 19, 2008 | 04:20 PM
Default Re: (project dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project dc2 &raquo;</TD></TR><TR><TD CLASS="quote">blox are 10X1.5
revhard are 10X1.25</TD></TR></TABLE>
i have those ebay cast ones so im not sure which one they used.
Old Feb 22, 2008 | 03:19 AM
anyone know where i can get this online?
Old Feb 22, 2008 | 07:21 AM
TheShodan's Avatar
Moderator
Many hardware stores and tractor repair have these.
Old Feb 22, 2008 | 09:30 AM
Default Re: (TheShodan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheShodan &raquo;</TD></TR><TR><TD CLASS="quote">Many hardware stores and tractor repair have these.</TD></TR></TABLE>
cool ill check it otu for sure.
Old Feb 22, 2008 | 09:46 AM
Dunc's Avatar
BCICAN
Ace Hardware has plenty of these studs. They are in the bolt section in the box labeled "Automotive Studs". I just bought an M10x1.25 stud for my bike two days ago.
Old Feb 22, 2008 | 11:25 AM
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote">Ace Hardware has plenty of these studs. They are in the bolt section in the box labeled "Automotive Studs". I just bought an M10x1.25 stud for my bike two days ago. </TD></TR></TABLE>
damn i went to hawaii nut and bolt, and napa. i forgot which one i found 10x1.25 or 10x1.5 only at napa, but not at hawaii nut and bolt. Oh wells. ill check out ACE in hawaii.
Old Feb 22, 2008 | 05:08 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integlspwr2k &raquo;</TD></TR><TR><TD CLASS="quote">so 1.25 is for hondas? or 1.5?
haha im lost.</TD></TR></TABLE>
your lost for good reason, revhard has been known to mess up and tap there manifolds to 1.25, there supposed to be 1.5 but a lot of them are 1.25 due to using the wrong tap by mistake... revhard
Old Feb 22, 2008 | 05:20 PM
Default Re: (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">
your lost for good reason, revhard has been known to mess up and tap there manifolds to 1.25, there supposed to be 1.5 but a lot of them are 1.25 due to using the wrong tap by mistake... revhard </TD></TR></TABLE>.
man to revhard.
Old Feb 23, 2008 | 10:30 AM
Evilparadize's Avatar
What about the Meutek manifold bolt size? (Turbo to Manifold) Do they have to be heat treated or do ACE bolts hold up pretty well?
Old Feb 23, 2008 | 11:12 AM
Dunc's Avatar
BCICAN
Default Re: (Evilparadize)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">your lost for good reason, revhard has been known to mess up and tap there manifolds to 1.25, there supposed to be 1.5 but a lot of them are 1.25 due to using the wrong tap by mistake... revhard </TD></TR></TABLE>
It's just a different thread pattern. That doesn't make it "wrong" or bad...just means you need a different type of bolt to work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evilparadize &raquo;</TD></TR><TR><TD CLASS="quote">What about the Meutek manifold bolt size? (Turbo to Manifold) Do they have to be heat treated or do ACE bolts hold up pretty well? </TD></TR></TABLE>
The ACE studs are black. Black are the strong ones....you'll be plenty fine. I've used them before on my turbo setup for over a year with no problems at all. Those bolts don't really need to be like super high strength because they are only holding up like 20lbs or so. It's no where near the forces that a strut bolt would see or something like that.
Old Feb 23, 2008 | 12:46 PM
ILcrxsi1's Avatar
I tell doctors what to do
your lost for good reason, revhard has been known to mess up and tap there manifolds to 1.25, there supposed to be 1.5 but a lot of them are 1.25 due to using the wrong tap by mistake... revhard </TD></TR></TABLE>I was going to say that I could have sworn to god that my revhard manifold was 1.5. I wouldn't really give them a thumbsdown either they make a pretty damn durable cast iron manifold. It accomplishes exactly what it's supposed to do.
Old Feb 23, 2008 | 03:05 PM
blinx9900's Avatar
Default Re: (Dunc)
i understand but when your a revhard dealer and your customers yell at you like you dont know what your talking about cause someone at revhard used the wrong tap its a bit frustrating, then you call revhard and ask them why the last batch of manifolds had 1.25 instead of 1.5 and the guy laughs and say they just messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILcrxsi1 &raquo;</TD></TR><TR><TD CLASS="quote"> I wouldn't really give them a thumbsdown either they make a pretty damn durable cast iron manifold. It accomplishes exactly what it's supposed to do.</TD></TR></TABLE>
im giving them a thumbs down for more than that, i stopped being a dealer becuase so many of there manifolds cracked i got sick of sending them back. they used to make good manifolds but they reduced the amount of metal being poured into the molds and they crack A LOT now, and the fact that there turbo kits now come with an ebay blow off valve, it was very sad to see a company that was once so good fall apart, thats why i give them one of these
Old Feb 24, 2008 | 07:26 AM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 &raquo;</TD></TR><TR><TD CLASS="quote">i understand but when your a revhard dealer and your customers yell at you like you dont know what your talking about cause someone at revhard used the wrong tap its a bit frustrating, then you call revhard and ask them why the last batch of manifolds had 1.25 instead of 1.5 and the guy laughs and say they just messed up.</TD></TR></TABLE>
haha, seriously though I feel bad that you have that retarded of customers. If you (customer) can't figure out what bolt to use and have to call the dealer up and complain....then put the tools down, step away from the car, and sell your turbo kit. You're not mechanically inclined enough if you are unable to do this simple of a task. It doesn't take a rocket scientist to figure out A.) test a couple different thread patterns or B.) take your damn manifold to the hardware store
Old Feb 24, 2008 | 02:50 PM
blinx9900's Avatar
Default Re: (Dunc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dunc &raquo;</TD></TR><TR><TD CLASS="quote"> It doesn't take a rocket scientist to figure out A.) test a couple different thread patterns or B.) take your damn manifold to the hardware store </TD></TR></TABLE>
cant argue with that
Old Feb 24, 2008 | 03:22 PM
inspyral's Avatar
Default Re: (Dunc)
I've done this, and not just with turbo parts.
The strange look you get from the cashier when you push your cart to the front is a nice bonus.
s.cha
May 11, 2009 08:44 PM
dohckiller
Jun 21, 2006 07:15 PM
97lx
Nov 15, 2004 01:15 PM
