Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Radiator support is bent, replace or repair?
Old Feb 18, 2008 | 10:43 PM
GundamONE's Avatar
Default Radiator support is bent, replace or repair?
Freak accident, but in the end I can see my radiator support frame is bent up and has pushed up the radiator and everything else. The car continues to cool fine, but if I replace my radiator down the line then I'm sure a shop will tell me to correct it. I need to find out what I am looking at in terms of my options.
I have a 2001 Civic EX coupe. All I know is that it's welded on and that I do not have any option of doing it myself. I don't make a huge amount of dough, so I'm guessing this fix is going to hit me hard on my wallet. Should I just get it replaced or repaired? How much does something like this run? (any past experiences with this would be appreciated) and how long does something like this take? I commute quite a bit everyday so I hope I won't be stuck with a rental for too long. Any referrals to a good place in the So Cal - L.A. area would be great also. Thanks in advance for any help!
Jeff
Old Feb 18, 2008 | 11:45 PM
TOEnail's Avatar
Default Re: Radiator support is bent, replace or repair? (GundamONE)
i'm in the same boat as you are but i'd recommend that you'd replace it for safety reasons.
since you have an EX you'd probably need to replace the ac condenser as well.
you can try craftman auto body on studebaker right next to cerritos auto square. it won't be cheap but they do good work. or you can try pming nautical_star, since he works at kings auto body.
Old Feb 19, 2008 | 03:45 PM
GundamONE's Avatar
Default Re: Radiator support is bent, replace or repair? (TOEnail)
Hey TOEnail thanks for the reply. I'll keep the information you posted in mind.
Jeff
Old Feb 19, 2008 | 10:11 PM
Nautical_Star's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOEnail &raquo;</TD></TR><TR><TD CLASS="quote">
you can try craftman auto body on studebaker right next to cerritos auto square. it won't be cheap but they do good work. or you can try pming nautical_star, since he works at kings auto body.</TD></TR></TABLE>
Hahaha good looking out homie.
Old Feb 19, 2008 | 11:07 PM
Dark@Powers's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TOEnail &raquo;</TD></TR><TR><TD CLASS="quote">i'm in the same boat as you are but i'd recommend that you'd replace it for safety reasons.</TD></TR></TABLE>
Old Feb 20, 2008 | 08:58 AM
DNRperformance's Avatar
replace!
Old Feb 21, 2008 | 08:15 AM
The good thing is that your radiator isn't leaking any coolant and how's your condensor? And when you say it's been pushed up does that mean the lower portion of your rad. support was damaged? If so it wouldn't be a great idea to repair it but rather replacing it would be best. Leaving a damaged rad. support alone for a long time isn't good for the car due to the fact that rusting comes into play. You can always resort to getting an aftermarket OEM rad. support which could be cheaper by like $100, but your best bet is to replace it without thinking twice cause I've seen really bad rad. supports from customers leaving it alone for years... If you have any further questions just PM me again and I'll see what I can do for you.
Old Feb 21, 2008 | 08:43 PM
GundamONE's Avatar
Default Re: Radiator support is bent, replace or repair? (Nautical_Star)
Thanks for the input Nautical_Star. I'm going to try to start calling up a few places to see if they can get me an estimate on what's it going to cost. Let me know if you can give me an estimate on how much some of your previous jobs were to give me an idea on what I should be looking out for. I haven't a clue what labor looks like on these types of things. Thanks.
Jeff
Old Jan 2, 2009 | 09:15 PM
Shintakun's Avatar
Hey, by a chance does it matter if its a AT radiator? i want to replace mine as well. but there are options for Denso or Toyo AT ot MT
Old Oct 14, 2009 | 05:05 PM
str8civic95's Avatar
New User
i have done many supports it not to hard and if you know how to weld alittle. all you need it a spot weld drill bit and you can drill out all the welds.
rudebwoy
May 11, 2014 07:43 PM
dogbiscuit
Feb 15, 2006 09:20 PM
drunknmunkypow
Aug 10, 2003 07:40 AM
B18CYAAA
Jul 14, 2003 03:22 PM
