why wont the key come out the ignition???
Old Feb 18, 2008 | 08:36 PM
2ndchirp's Avatar
Default why wont the key come out the ignition???
on my friends 1992 prelude si the key after turnin off the car wont come out of the ignition... its a weird problem it locks in there untill we disconnect the negative terminal from the battery, then we can pull out the key
Old Feb 18, 2008 | 09:12 PM
busyychild's Avatar
Default Re: why wont the key come out the ignition??? (2ndchirp)
sorry if this sounds obvious, but i had to show this to lackey at the tire shop the other day. you have to push the key in while turning left to get it outta the ignition.
if thats not it then i don't know. i don't know what could possible be grabbing onto the key while it has power.
Old Feb 18, 2008 | 09:30 PM
2ndchirp's Avatar
Default Re: why wont the key come out the ignition??? (busyychild)
yes we tried turnin the key..it has always worked fine...it just happened recently after swapin the automatic trans for a 5speed
Old Feb 18, 2008 | 09:41 PM
dagle's Avatar
are u sure its not the weight on the steering wheel? like when it gets stuck, try turning the wheel left and right while pulling the key out the usual way..?
Old Feb 19, 2008 | 09:45 AM
axlline's Avatar
There is your problem, in the auto's there is a sensor that wont let you take the key out unless the car is in park. Since you no longer have park, it won't let you take it out.<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2ndchirp &raquo;</TD></TR><TR><TD CLASS="quote">yes we tried turnin the key..it has always worked fine...it just happened recently after swapin the automatic trans for a 5speed</TD></TR></TABLE>
Old Feb 19, 2008 | 10:47 AM
2ndchirp's Avatar
Default Re: why wont the key come out the ignition??? (axlline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by axlline &raquo;</TD></TR><TR><TD CLASS="quote">There is your problem, in the auto's there is a sensor that wont let you take the key out unless the car is in park. Since you no longer have park, it won't let you take it out.</TD></TR></TABLE>
ooo.. wow... i feel so stupid... is there a way that the problem can be fixed????
Old Feb 19, 2008 | 11:29 AM
axlline's Avatar
Did you take out the TCM? What did you do with the wires that went to the auto shift lever?
Old Feb 19, 2008 | 12:28 PM
no1knows908's Avatar
Good think I caught this thread, I might have totally missed this when I do my swap this easter. What has to be done to prevent this?
Old Feb 19, 2008 | 02:59 PM
JasonST's Avatar
Default Re: why wont the key come out the ignition??? (no1knows908)
Take out or discconnect the autolock box down by where the clutch pedal is.
Old Feb 19, 2008 | 08:42 PM
2ndchirp's Avatar
Default Re: why wont the key come out the ignition??? (JasonST)
i swapped the ecu.... we had to bypass the neutral safety switch so the car will turn on... so i set the shift lock box to park and tapped the 2 wires toghether that make the parkin connection
1sikhatch
Apr 9, 2010 08:41 AM
BuDDaH7o7
Jan 21, 2008 12:03 PM
efrex
Mar 1, 2007 07:58 AM
dc2go
May 23, 2005 10:33 AM
qcktegls
Jan 9, 2005 03:52 PM
