replacing lca + coilover kits
ok i looked at the picture that the dealership showed me. What the difference between 34 and 35? it look like the exact same thing. I thought i need another bolt that the coilover sits on. Anyone know the part number?
are you talking about the bolt that bolts the bottom of the shock to the LCA? If so, the part number is 90172-SK7-A01
It is #14 on the Rear Shock Absorber page.
ok i grinded the bolt that the strut sat on (that came off plus the strut), I took the inner bolt out wihout a problem. Now im stuck with the bolts that underneath the hub. I try to grind it off but no room. Would the saw will do the job? ?/
i'm having the same problem right now with my DC. it sux
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 401B18TEG »</TD></TR><TR><TD CLASS="quote">is all 3 bolts on the lca the same?</TD></TR></TABLE>
i think they are the same but at different lenght. each of those cost a lot.
