2000 Si sat for 4 yrs.
I would change all fluids including the brake fluid. I would also check all wires under the hood for rat damage (chewed wires and such)
A battery is probably needed
Check tires for weathering (Cracks and such)
If it has semi good paint a wash and a wax.
And after a few miles (200) I would change the oil again.
That should do it!
That should do it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman »</TD></TR><TR><TD CLASS="quote">I would change all fluids including the brake fluid. I would also check all wires under the hood for rat damage (chewed wires and such)
That should do it!</TD></TR></TABLE>
dont forget the fuel system. hopefully it was stored properly. drain any fuel (goo) in the tank and change the fuel filter. i would change the filter again after a couple hundred miles. hopefully the fuel rail and injectors arent gunked up
My 88 crx si was sitting for 4 years before I got it and I did these and I have not had one problem with it (Knocks on wood)
H23_del_soul
Apr 9, 2010 07:21 AM
jibs
Jul 6, 2006 05:24 PM
.....deff give it a full tune up before running it....if it runs that is
