PLEASE HELP
Old Feb 18, 2008 | 02:19 PM
jdm5596's Avatar
Default PLEASE HELP
lets start from the beginning... i was throwing a tps code, so i looked at my sensor. wire was broken, so i put it back together and took out the fuse to the ecu to reset it. put it back in, and tried to start the car. car wouldnt start... un hook the fixed wire, still no start... changed ecus. still no start. got fuel, got spark, turns over fine. sounds good turning over. just doesnt start. i even put some fuel into it manually, no start.... what is going on?
i really need some help people!!!!!!
Old Feb 18, 2008 | 02:26 PM
thesmogman's Avatar
Default Re: PLEASE HELP (jdm5596)
When you pulled the fuse was the key in the on position? Check the fuse. I hope you were pulling the hazard fuse. If you stuffed the fuse in while it was on you might have blown the fuse or maybe another. Check all fuses first and get back to us.
Dc295kid
Jan 1, 2011 04:47 PM
#1 Dominican
Dec 27, 2008 12:50 PM
Tad
16
Aug 4, 2005 03:56 PM
tuan...
Nov 3, 2003 08:24 PM
MeanGreenEG9
May 6, 2003 05:02 AM
