burning oil
Old Feb 18, 2008 | 01:41 PM
94DB8's Avatar
Default burning oil
me teggy burnt about 2.5 qts. of oil in almost 1-2 months is this normal? im using mobil clean 5000 10w30
Old Feb 18, 2008 | 04:01 PM
ls19integra95's Avatar
Default Re: burning oil (94DB8)
im using same oil as you, im not burning any at all... do you see any smoke coming out of exhaust? your piston rings need to be replaced... also you sure your not leaking some of that oil...
Old Feb 18, 2008 | 04:43 PM
Fern413's Avatar
check first to see if your engine is leaking any oil
Old Feb 18, 2008 | 05:50 PM
friesx100's Avatar
I'd have to say that's an unhealthy amount.
Look around- ground, engine, enhaust..
ALSO. Depending on what you have and where you live.. I believe its reccomended to use 5w30. Not sure if that'd make much of a diff tho. (Look on your oil cap :D)
Old Feb 18, 2008 | 06:04 PM
94DB8's Avatar
i park in my drive way and theres absolutely no oil ... if i let it idle for a long time some black substance comes out of the exhaust but i think its just wet carbon or somethin im pretty sure its not oil ... would a leakdown test be able to tell me if my rings are fried? its bone stock ....
Old Feb 18, 2008 | 06:35 PM
jeb97gsr's Avatar
Default Re: (94DB8)
It might be your valve seals. From what I have been told it is a common problem.I just ordered some new ones today for my car.
Old Feb 19, 2008 | 04:14 AM
94DB8's Avatar
hmmmm ok ... how hard is it to do that? (jeb97gsr)
Old Feb 19, 2008 | 04:23 AM
ac_attak's Avatar
How many miles did you put on it in that time frame? What engine?
Old Feb 19, 2008 | 06:03 AM
94DB8's Avatar
idk prob around 2k miles ... b18c1
Old Feb 19, 2008 | 11:40 AM
St Jimmy's Avatar
* B A N N E D *
Default Re: (94DB8)
Do a compression/leakdown test, it should tell you where the oil is going.
Old Feb 20, 2008 | 04:28 PM
94DB8's Avatar
ok thanks
carbonemt
Apr 19, 2011 10:03 AM
serjey15
Dec 4, 2010 07:20 PM
diluted
Jan 17, 2004 07:54 PM
CroSi
Aug 14, 2003 04:32 PM
LB CRX
Oct 20, 2002 08:14 PM
