Code 41
you up and down idle is most likely caused by your idle control motor and the IACV.....cleaning them out and maybe minor adjustment should solve the problem
Yep, I believe there is a good article about cleaning and adjusting your FICV (Fast Idle Control Valve) which is located under your throttle body. This is the culprit for the idle, but not your thrown code. While your at it, clean out the IACV as well...
good luck!
sohc
good luck!
sohc
reed857
29
Jul 26, 2009 10:57 AM
Glocked1
12
Jan 22, 2004 08:13 PM
