Code 41
Old Feb 18, 2008 | 12:47 PM
mike1409's Avatar
Default Code 41
I have a cel code 41. What I found it meant was bad o2 sensor. Would that make my car idle up and down? It is a 94 Accord
Old Feb 18, 2008 | 04:33 PM
hondadude's Avatar
Default Re: Code 41 (mike1409)
This might help you with the O2 sensor HEATER CIRCUIT problem
This shouldn't actually cause any radical RPM swings at idle
Old Feb 18, 2008 | 08:59 PM
bseriescrxsi's Avatar
you up and down idle is most likely caused by your idle control motor and the IACV.....cleaning them out and maybe minor adjustment should solve the problem
Old Feb 18, 2008 | 09:10 PM
SOHCMAN's Avatar
Default Re: Code 41 (bseriescrxsi)
Yep, I believe there is a good article about cleaning and adjusting your FICV (Fast Idle Control Valve) which is located under your throttle body. This is the culprit for the idle, but not your thrown code. While your at it, clean out the IACV as well...
good luck!
sohc
h23prelude
Jun 8, 2010 02:16 PM
reed857
29
Jul 26, 2009 10:57 AM
poppypizza
May 1, 2008 07:47 PM
Pyronus
Aug 13, 2006 12:28 PM
Glocked1
12
Jan 22, 2004 08:13 PM
