Passenger is axle is popping out help!
Old Feb 18, 2008 | 12:25 PM
Frost7177's Avatar
Default Passenger is axle is popping out help!
Let the g.f take the car out the other day and hit a damn curb lower control arm was screwed also the part where the axle slides into the tranny the part inside the boot popped out. I replaced the lower control arm and the axle. the top of the tire is pointed out past the fenderabout and inch out can caster and camber be the screwed up from that. Also the axle is slipping out.When its in all the way i cant even turn it by hand whats up with this? Do ex's have abs its a 97 ex.
Old Feb 18, 2008 | 01:16 PM
Frost7177's Avatar
Default Re: Passenger is axle is popping out help! (Frost7177)
bump someone has to know?
Old Feb 18, 2008 | 01:41 PM
95jeremie's Avatar
ok so look at your caliper if there is 2 hoses going to it than you have abs
if only one than well you don't have abs. at least that's my understanding.
i don't and only have one line.
as far as your axle problem...
there is something bent or way out of line.
go and get an alignment and you will at least know where you stand
Firestone has a lifetime alignment for like $160
it's not the best but i can now get an alignment every day if i want to.
Old Feb 18, 2008 | 01:51 PM
Frost7177's Avatar
Default Re: Passenger is axle is popping out help! (95jeremie)
the axle is popping out i cant even drive it there. When i try to push it in all the way it feels like something is in the way.
Old Feb 18, 2008 | 01:54 PM
instrument's Avatar
do not waste money with an alignment, if the top of the tire is that far from the wheel well you obviously bent something.
Old Feb 18, 2008 | 02:23 PM
Syndacate's Avatar
Default Re: (instrument)
Is that stupid O ring inside where the axle goes into the transmission seated properly?
Old Feb 18, 2008 | 02:31 PM
nub's Avatar
nub
Default Re: (Syndacate)
when you put the axle in you have to get it past the spring clip on the axle stub. ive never been able to "push" it in place, takes more of "jab" to snap it in.
Collsj
Honda CR-V & Element
Jun 19, 2017 09:38 AM
Collsj
Transmission & Drivetrain
May 6, 2017 12:43 PM
dtran002
May 18, 2012 10:47 PM
DanDaMan
Jan 21, 2006 08:49 AM
94rsvtec
Mar 10, 2004 12:28 PM
