whats wrong with my car?
Old Feb 18, 2008 | 09:22 AM
nraugnus's Avatar
Default whats wrong with my car?
ok i dont know whats wrong with my car. please help
when i rev it up high its sound like it is backfiring and the speed wont pick up
please help me, i dont know whats wrong with it
heres some videos
Engine:
http://youtube.com/watch?v=Pvcp2Qh0HOM
Shifting from 3rd gear to 2nd going full throttle on 2nd gear:
http://youtube.com/watch?v=lky6COzaqFY
Old Feb 18, 2008 | 09:26 AM
nraugnus's Avatar
Default Re: whats wrong with my car? (nraugnus)
help,
Old Feb 18, 2008 | 09:32 AM
nraugnus's Avatar
someone
Old Feb 18, 2008 | 09:41 AM
pgpunkguy's Avatar
what did you do to it? (ie what have you changed lately)
Old Feb 18, 2008 | 09:42 AM
nraugnus's Avatar
Default Re: whats wrong with my car? (pgpunkguy)
well, i put a 4-2-1 header on it and went to MN and back to WI. a total of 700 miles. and when i got back i ran over a pile of water twice than after that this just started happening
Old Feb 18, 2008 | 09:44 AM
DCSportEJ1Civic's Avatar
you have a misfire
Old Feb 18, 2008 | 09:45 AM
nraugnus's Avatar
Default Re: whats wrong with my car? (DCSportEJ1Civic)
how do i fix it? what to replace?
Old Feb 18, 2008 | 10:07 AM
Slick o9's Avatar
yea sounds like a misfire just replace the plugs and wires not that expensive...nice to do anyway.
JDM Lyfestyle's Avatar
Leave your engine idling then go pull each of your spark plug wires out one by one and listen if the engine changes, put it back in, if it doesnt then shut it off and pull that spark plug and check it out
Since your ran through water its most likely your plugs or wires..
If you want can just replace them all if you got the cash on hand..
Old Feb 18, 2008 | 10:13 AM
pizzzz's Avatar
try changing your distributor cap
Old Feb 18, 2008 | 10:14 AM
pizzzz's Avatar
try changing ur distributor cap n rotor
Old Feb 18, 2008 | 10:22 AM
B serious's Avatar
Cool Cool Island Breezes. BOY-EE
Pull each plug wire. The engine speed should drop and the idle should get worse. If you pull any plug wire and the engine speed either barely changes, or doesn't change at all, you just found the cylinder with the misfire.
The misfire could be several things. Some major, some minor.
Check for water in the actual plug hole, check to see if you're getting spark on that cylinder. Take out the spark plug, inspect it, and look for water in the hole or on the spark plug body. If there is water there, dry the plug throughly. Then put a rag on a stick and clean the plug hole. Try to get it as dry as possible.
Check the distributor connections for the spark plug wires and make sure they're dry also. Take off the distributor cap, make sure it's dry inside.
If that is not your issue, you may have to spend some timediagnoising it. It may be a good idea to take it somewhere in that case.
Old Feb 18, 2008 | 12:17 PM
pgpunkguy's Avatar
Default Re: (B serious)
as suggested before, i'd pull the plugs, inspect the plugs, let the block air-dry for a while (or overnight), pull the distributor cap and inspect the cap & rotor. replace what may need replaced and reassemble.
Old Feb 18, 2008 | 04:04 PM
gen2integra2001's Avatar
its something with your ignition..check your spark plugs and wires...mine did the samething when 1 of my spark plugs failed
celluloidheros
Jul 20, 2012 09:22 AM
IntegraUC
Feb 16, 2009 08:30 PM
prelude_93vtec
Jul 17, 2007 01:48 PM
kim_2_da_chee
Feb 16, 2003 10:52 AM
