Modify z6 dizzy?
Old Feb 17, 2008 | 09:14 PM
SH's Avatar
SH
Default Modify z6 dizzy?
How would I need to modify the z6 dizzy to fit on the y8 head... I heard I had to so how do I... Pictures anyone?
Old Feb 17, 2008 | 11:22 PM
ddd4114's Avatar
Default Re: Modify z6 dizzy? (SH)
You can find a b7/y7/y8 dizzy for dirt cheap, and it would be worth paying the money for one.
Old Feb 18, 2008 | 08:32 AM
SH's Avatar
SH
Default Re: Modify z6 dizzy? (ddd4114)
I already have the y8 dizzy and the B7 one... the y8 wont woek bc its missing a plug that the Cx harness has and the y8 dissy dosent. The B7 dizzy is still sluggish, but feels better than the B8 that I had in there.
Old Feb 18, 2008 | 10:42 AM
ddd4114's Avatar
Use the distributor that is compatible with your wiring harness (and your head).
On another note, are you sure your ignition/mechanical timing is correct?
Old Feb 18, 2008 | 09:36 PM
SH's Avatar
SH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">Use the distributor that is compatible with your wiring harness (and your head).
On another note, are you sure your ignition/mechanical timing is correct?</TD></TR></TABLE>
How would I know the ignition is in timing? Also how would I do this?I know the engine its self is in timing bc I drove the car that I took it out off.
Old Feb 18, 2008 | 09:57 PM
ddd4114's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SH &raquo;</TD></TR><TR><TD CLASS="quote">How would I know the ignition is in timing? Also how would I do this?I know the engine its self is in timing bc I drove the car that I took it out off.</TD></TR></TABLE>
Do you have a timing light?
Also, just because the engine runs, doesn't mean the timing is correct.
Old Feb 19, 2008 | 12:55 AM
SH's Avatar
SH
I know for a fact the engine is in its proper time... I drove the donar car a few time and ran perfect no problems at all. Ill try retarding or de retarding it the dizzy to see if this might be the issue. After all it is a P28 ECU running a Y8 which was never made to run the Y8 unless chiped with the Y8 map on it. Thanks for all your guys help... Ill inform on the situation as soon as I can.
Old Feb 19, 2008 | 02:45 AM
StorminMatt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ddd4114 &raquo;</TD></TR><TR><TD CLASS="quote">Use the distributor that is compatible with your wiring harness (and your head).</TD></TR></TABLE>
Actually, first an foremost, get the right distributer for your head. It's MUCH easier to modify your wiring harness than it is to moify a distributer to fit a different head.
Old Feb 19, 2008 | 05:05 AM
ddd4114's Avatar
Default Re: Modify z6 dizzy? (StorminMatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StorminMatt &raquo;</TD></TR><TR><TD CLASS="quote">Actually, first an foremost, get the right distributer for your head. It's MUCH easier to modify your wiring harness than it is to moify a distributer to fit a different head.</TD></TR></TABLE>
All the distributors I mentioned are compatible with his head. The z6/z1/d15b distributors are not compatible.
Old Feb 19, 2008 | 09:21 AM
SH's Avatar
SH
All the distributors I mentioned are compatible with his head. The z6/z1/d15b distributors are not compatible.</TD></TR></TABLE>
Good call going o mess with the clock wise and counter clock wise on the dizzy... that has to be the problem I know it. Thank you guys again for your help
Old Feb 19, 2008 | 10:04 AM
ddd4114's Avatar
Make sure you use a timing light when you change your ignition timing. A few degrees can make a difference.
Old Feb 19, 2008 | 01:10 PM
SH's Avatar
SH
Well the car is fixed looked like it needed to be counter clockwise runs good and isnt sluggish no more. Thanks for the help y'all....
PardonmyEK9
60
Mar 23, 2011 05:04 PM
jvillagran2000
27
Dec 3, 2008 05:06 PM
boomnn
Mar 28, 2008 04:22 PM
Super Chicken
Mar 7, 2005 06:15 PM
94dxt
Dec 26, 2003 08:49 PM
