1995 eg civic coupe rattling
Old Feb 17, 2008 | 08:02 PM
CiViCBruh's Avatar
Default 1995 eg civic coupe rattling
My car rattles alot beacause of my huge exhaust. Is there anyway to make the rattling go away? It is mostly in the doors and some in the dash.
Old Feb 17, 2008 | 08:04 PM
DCSportEJ1Civic's Avatar
Default Re: 1995 eg civic coupe rattling (CiViCBruh)
if your doors are rattling from your exhaust its too loud
Old Feb 17, 2008 | 08:05 PM
Thateguhate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CiViCBruh &raquo;</TD></TR><TR><TD CLASS="quote">My car rattles alot beacause of my huge exhaust. Is there anyway to make the rattling go away? It is mostly in the doors and some in the dash.</TD></TR></TABLE>
thats not your exhaust. Check your motor mounts... etc..
Old Feb 21, 2008 | 08:09 AM
CiViCBruh's Avatar
the mounts are tight?
Old Feb 21, 2008 | 09:11 AM
Remington's Avatar
Default Re: (CiViCBruh)
ok they're tight...... are they torn? solid mounts? first order of buisness if you have loud rattles is to track them down find out what's rattling 9/10 its a loose screw or bolt that takes an hour to find. Also consider (If you have subs) turning down the bass a bit see if that helps.
Old Feb 21, 2008 | 09:13 AM
crazyguy's Avatar
make sure there is no damange or crack on the motor mounts and also check your exhaust rubber hangers,
Old Feb 21, 2008 | 10:23 AM
[ivi]'s Avatar
Default Re: (crazyguy)
Probably his exhaust hitting the heat shield. I bet he still has it on stock.
Old Feb 21, 2008 | 10:53 AM
ke98248's Avatar
Default Re: ([ivi])
Either that or its hitting the shift linkage -- or the chassis of the car.
ohemgiii
14
Oct 3, 2015 03:52 AM
jkalex05
Sep 17, 2012 05:09 AM
Charlie Moua
Sep 20, 2011 02:53 PM
the171
Mar 30, 2010 05:14 PM
blazinb16
May 23, 2003 09:03 AM
