2000 civic si help
how do you know if you have a bad pistons or rods(my car does not start up ...but it will crank up..)i drove the car the other day and it was runing fine ....
i just found out my cluster and radio don't work ..but my barttery is good horn work very well..and i didn't not hear the buzzing noise when you turn the ignition on
no problem then, if your rod or piston was bad and you were cranking the car you would hear it.
and engine needs 5 basic things to run and these are the only things that can be taken away that will keep it from running.
fuel
air
spark
timing
compressing
figure out what you DONT have, and then figure out why. and make friends with people that know how to work on cars. as long as your willing to read and learn you should have no problem.
fuel
air
spark
timing
compressing
thanx for the info... i will try the step 2mmmorw ...1 other qustion how come my cluster and radio don't work ..but my barttery is good (i check the fuse under the hood and it look good? and didn't not hear the buzzing noise when you turn the ignition on
the battery is in great shap(i try the horn test)even check the fuse under the hood 7.5 a amp ..... i know that i do not have bad pistion and rod b/c the motor only have 58k mile on it
royalaccord92
Jul 14, 2018 10:55 PM
em194
20
Sep 6, 2011 10:38 AM
Shisno
Jul 24, 2009 12:54 PM
