e85 first start on a basemap?
Old Feb 17, 2008 | 04:38 PM
skoodles2k6's Avatar
Default e85 first start on a basemap?
ok guys heres the thing my car is just about completed. 12.2:1 ls/vtec
one of my other threads i was told i run a itr basemap just to start the car run it through the gears not planning on getting into vtec. but I'm planning on tunning my car on E85 will it be ok to start my car on e85 for its first cranking and will ie85 be ok on an itr basemap? so i dont have to drain it all out before i go to the dyno.
Old Feb 17, 2008 | 05:43 PM
bluedlude's Avatar
Default Re: e85 first start on a basemap? (skoodles2k6)
no. im not sure where the P72 map will put you as far as AFR's go but i can bet you will be super lean. unless you are doing real time editing dont even try it before you scale the map. shoot for about a 10.5:1 AFR to be safe and then tune it from there.
Old Feb 17, 2008 | 05:56 PM
2fastGSR's Avatar
King of the One Liners
Default Re: e85 first start on a basemap? (bluedlude)
you need more fuel when you run e85. I would not run a stock basemap on the initial start up for that reason but thats just my opinion
blkdoutteg
Engine Management and Tuning
14
May 5, 2019 11:05 AM
RACEPAK
Apr 29, 2016 07:20 PM
pliskin679
Oct 27, 2009 11:43 PM
poppypizza
13
Feb 16, 2008 10:25 AM
JDMRACER689
Aug 19, 2006 09:39 AM
