started another manifold..a20 sidewinder
Old Feb 17, 2008 | 03:40 PM
rorik's Avatar
Default started another manifold..a20 sidewinder
This is going to be kinda difficult to build because I don't have the car and motor, hopefully my visualization/memory will be adequate. Anyway, the turbo will be off somewhere above the intersection of the motor/tranny, and should clear the a/c and p/s. I'm not making this for anyone in particular, but people on 3geez.com always complain about no manifolds being available, so maybe one of them will buy this when it's done. Who knows. I'm still waiting for my head flange from weirtech, so this is all I've done so far. I thought twice about posting this up, but then I thought why not..
Old Feb 17, 2008 | 03:44 PM
Tippyman's Avatar
Building a mani with no engine/jig/car?
Old Feb 17, 2008 | 03:57 PM
rorik's Avatar
That's me, always fighting an uphill battle..
Old Feb 17, 2008 | 04:27 PM
robbbby's Avatar
Default Re: started another manifold..a20 sidewinder (rorik)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rorik &raquo;</TD></TR><TR><TD CLASS="quote">This is going to be kinda difficult to build because I don't have the car and motor, hopefully my visualization/memory will be adequate. ]</TD></TR></TABLE>
huh? so you're building it not knowing if it will fit, and then when finished won't even be able to test it out and see if it fits, but you're planning on selling it?
cool, i think.
Old Feb 17, 2008 | 05:07 PM
TurboSI56's Avatar
Default Re: (rorik)
Instead of welding a T3 flange on you should have made it flanged for the Tial T3 V-Band that way you'd have a much better chance of it working in the end
Old Feb 17, 2008 | 05:40 PM
wade's Avatar
You not going to bevel the ends of the runners on the collector?
Old Feb 17, 2008 | 08:18 PM
rorik's Avatar
Well, I have that same car, but mine has the b series motor. I used to have a turbo setup like what I'm building now back in the day, years ago. I was able to fit the a/c, p/s, the front motor mount, and a 3" downpipe. So I have a pretty good idea of how it should be set up. There are also a few pics I can get dimensions from, like this one.
Mine will be a little more equal length though.
Old Feb 17, 2008 | 10:28 PM
RC000E's Avatar
Default Re: (rorik)
No jig, no car, no motor.....whew....
Old Feb 18, 2008 | 12:57 AM
Lamchop0000's Avatar
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">No jig, no car, no motor.....whew....</TD></TR></TABLE>
i say go for it!
Old Feb 18, 2008 | 05:40 AM
AssItch1's Avatar
Default Re: (Lamchop0000)
indeed... good luck with that...
great idea though... im in the process of somewhat the same... here's mine..
Old Feb 18, 2008 | 05:59 AM
robbbby's Avatar
Default Re: (AssItch1)
how efficient are these manifolds that merge into one pipe, and have that one pipe run into the turbine inlet flange, as opposed to having the merge collector right at the turbine inlet. my manifold would have been so much simpler if i had done it that way. any pros/cons to this route when divided/twin scroll isn't a concern.
Old Feb 18, 2008 | 09:21 AM
rorik's Avatar
Right car, wrong motor, but previous experience and pics to look at..it will be a pain though.
Old Feb 18, 2008 | 09:42 AM
rorik's Avatar
Default Re: (robbbby)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by robbbby &raquo;</TD></TR><TR><TD CLASS="quote">how efficient are these manifolds that merge into one pipe, and have that one pipe run into the turbine inlet flange, as opposed to having the merge collector right at the turbine inlet. my manifold would have been so much simpler if i had done it that way. any pros/cons to this route when divided/twin scroll isn't a concern.</TD></TR></TABLE>
Like assitch1's manifold? What a screen name, damn..
I don't know. That's a really good question, I'd like to know more about that too. I think that would not be quite as efficient at preserving the energy of each exhaust pulse to the turbo, but as far as how much of a difference that makes in the real world, I don't know. It also probably depends on the length of the primaries and the length of that tube. I've also seen manifolds that look like an oem tri y header made into a top mount, with 2 tubes going up to the turbo, I always wondered about them too.
I would say as far as the single pipe to the turbo thing though, keep that pipe as short as possible? (But I'd prefer a little increased length on it over having ourageously long primaries..?) When I was first thinking about the manifold I'm working on now, I thought of having the collector point down, instead of using the 2" radius pipe, but everyone else does it that way, and the pipe is so short, I don't really see it making too much of a difference.
Definitely interested in more input on the long single pipe or double pipe thing..
My intuition is usually pretty good, but I'm really interested if anyone has any technical explanation here. (that can be backed up, sources cited, etc)
Old Feb 18, 2008 | 11:02 AM
AssItch1's Avatar
Default Re: (rorik)
my single pipe is probably a bit long... but that has to do with the rest of the setup...
i wont be using an intercooler... so that should cancel out a bit of the ineffectiveness...
it's probably true that this way you dont get enough use of the heat and pulses for the turbo... but we'll see what it does...
glad you like my screenname
Old Feb 18, 2008 | 12:46 PM
rorik's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssItch1 &raquo;</TD></TR><TR><TD CLASS="quote">
What, with further ineffectiveness?
You gotta admit, you walked into that one..
Old Feb 18, 2008 | 01:01 PM
AssItch1's Avatar
Default Re: (rorik)
what i meant was i wont be using an intercooler in the normal way... not some huge thing mounted in the front bumper... it'll be an air/water intercooler... doubling as an intake manifold
Old Feb 18, 2008 | 01:07 PM
drumking15's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssItch1 &raquo;</TD></TR><TR><TD CLASS="quote">what i meant was i wont be using an intercooler in the normal way... not some huge thing mounted in the front bumper... it'll be an air/water intercooler... doubling as an intake manifold </TD></TR></TABLE>
def wanna check that out...post some pics when you done
Old Feb 18, 2008 | 08:34 PM
rorik's Avatar
Doubling as the intake manifold? So how will you avoid a small surface area with a high velocity and pressure drop across it?
Old Feb 19, 2008 | 11:08 AM
AssItch1's Avatar
Default Re: (rorik)
i'll post pics when im done
i'll be using a garrett core... they sell it at atpturbo.com... it can handle 1000hp worth of airflow... so i think i'll be good....
Old Feb 19, 2008 | 12:27 PM
supergenius's Avatar
I spy Tial Hotside????
Old Feb 19, 2008 | 12:30 PM
AssItch1's Avatar
Default Re: (supergenius)
good eyes
Old Feb 21, 2008 | 03:01 PM
rorik's Avatar
here are some more pics..almost done, just don't know what to do with the wastegate yet. Either the 44mm v band tial, which I prefer, or the 38. Either way, this thing better fit the car..
Old Feb 21, 2008 | 03:36 PM
boost_aholic97's Avatar
Default Re: (rorik)
looks pretty good, did you back purge that?
Old Feb 21, 2008 | 05:00 PM
rorik's Avatar
Yes. Argon backpurged..
No, I just stuck duct tape on ithe turbo flange opening for the hell of it..
Modified by rorik at 7:14 PM 2/23/2008
Old Feb 22, 2008 | 04:09 AM
Ovrbst_T66's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AssItch1 &raquo;</TD></TR><TR><TD CLASS="quote">indeed... good luck with that...
</TD></TR></TABLE>That manifold looks very nice,but you might wanna fab up a heatshield on that clutch slave cylinder or wrap it.The heat from the turbo is going to give to shifting issues.
