H22 Dizzy Wiring? Where does the light blue & black/yellow wire goes to?
Old Feb 17, 2008 | 12:39 PM
trooper0641's Avatar
Default H22 Dizzy Wiring? Where does the light blue & black/yellow wire goes to?
A friend of mines recently purchased a EK w/ a h22 engine in there, obd2 to obd1 conversion.
The wiring job that came with the car is horrible (a rigged up 1 peice harness (no shock tower harness/clips) just a whole engine harness running straight to the ecu.
I got most of the problems and bugs fixed.. now I'm left with just a dizzy wiring problem. The car is throwing a code 10 and a code 4. Something to do with the crank position or some sh*t.
I got 2 dizzy wires that are probably not rigged up correctly and was wondering if anybody knew where the light blue and the black/yellow wire goes to (straight to the ecu, which pins) this is on a p28 ecu. I heard that the light blue wire is for the RPM tach.. and maybe the black/yellow wire for the possible code 4 crank position problem I have. As of right now the car's RPM tach is not working and is throwing a code 10 & 4.
these 2 goes to.. ?
?obd2 rigged engine harness > obd1 conversion harness > obd1 p28 ecu?
*using obd1 h22 dizzy*
4 CKP - crank position sensor
10 IAT - intake air temperature sensor
And the car drives like a car with it's timing off. Very slugish and 0 power. The #4 code problem is what im trying to solve mostly.
Modified by trooper0641 at 1:59 AM 2/18/2008
Old Feb 17, 2008 | 01:46 PM
Default Re: H22 Dizzy Wiring? Where does the light blue & black/yellow wire goes to? (trooper0641)
bump for ecu diagram info or something.
Old Feb 17, 2008 | 02:54 PM
dizzy wiring
Old Feb 17, 2008 | 03:32 PM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothread/650329
Old Feb 17, 2008 | 04:12 PM
kulrevon's Avatar
Default Re: H22 Dizzy Wiring? Where does the light blue & black/yellow wire goes to? (98vtec)
black/ yellow is power. Posibly to the main really but not sure.
I don't have my pin diagram book. tomorrow I can tell you where it is supposed to go.
The code 10 is Intake Air Temp.
The code 4 is for a CKP which is because the blue wire is probably the CKP P wire and on an obd2a it goes to CO2 and if its obd2b it goes to CO8. and if its obd1 B15.
Modified by kulrevon at 5:04 PM 2/18/2008
Old Feb 18, 2008 | 12:09 PM
Default Re: H22 Dizzy Wiring? Where does the light blue & black/yellow wire goes to? (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">black/ yellow is power. Posibly to the main really but not sure.
The code 4 is for a CKY which is because the blue wire is probably the CKY P wire and on an obd2a it goes to CO2 and if its obd2b it goes to CO8. and if its obd1 B15.
Modified by kulrevon at 8:33 PM 2/17/2008</TD></TR></TABLE>
please tell me more
Old Feb 18, 2008 | 12:41 PM
kulrevon's Avatar
like what more do you need? I told you where the blue was supposed to go.
And what the codes were.
just find where the black/yellow goes.
Old Feb 18, 2008 | 12:46 PM
98vtec's Avatar
moderator emeritus
CKY?
you mean CKP P
The reason the car runs sluggish is because the CKP sensor is needed to determine when to fire the injectors. the TDC sensor is down there as well so that should explain why the engine runs the way it does. Not to mention the IAT sensor is needed for correct startup and driving procedure.
Old Feb 18, 2008 | 01:06 PM
kulrevon's Avatar
yeah CKP I fixed it
Old Feb 18, 2008 | 01:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">like what more do you need? I told you where the blue was supposed to go.
just find where the black/yellow goes.</TD></TR></TABLE>
if you happend to have a ecu diagram or can tell me which pin where c02 and the others are exactly on a p28 ecu.. that would be great. thanks
Old Feb 18, 2008 | 01:58 PM
thanks for the info
Old Feb 18, 2008 | 02:00 PM
kulrevon's Avatar
The blue wire needs to go to B15.
salman
10
Jul 6, 2006 05:41 PM
Daniel-sanB1
10
Jan 5, 2006 10:10 PM
bustah49
12
Jan 9, 2005 03:25 PM
junglerunna
Apr 28, 2003 09:27 AM
baonest1
Mar 18, 2003 09:48 AM
