Throwing a random CEL..
Old Feb 17, 2008 | 12:16 PM
s0ulj3r's Avatar
Default Throwing a random CEL..
Well, I JUST noticed my speedo wasnt working and my CEL popped on.. I restarted my car and the CEL didnt come on but my speedo still didnt work, Think the connection to some sensor is loose or something? It randomly decides to work and when not to work, or when i am high revs it usually works..
Old Feb 17, 2008 | 01:25 PM
s0ulj3r's Avatar
anyone..?
Old Feb 17, 2008 | 07:39 PM
SilverBulletY8's Avatar
Default Re: Throwing a random CEL.. (s0ulj3r)
sounds like a connection to your speed sensor, depending on your tranny type could be a pain in the @$$... If could also be a bad speedo... does the odometer work. Normally if the speed sensor goes out it will throw a CEL, but if the speedo were bad, it wouldn't...
Old Feb 17, 2008 | 07:42 PM
DCSportEJ1Civic's Avatar
Default Re: (s0ulj3r)
sounds like the vehicle speed sensor or the connection to it.
Old Feb 17, 2008 | 08:53 PM
s0ulj3r's Avatar
Default Re: (DCSportEJ1Civic)
Wheres the speed sensor? Odometer still works along with RPM gauge and what not.. My car is a Manual, btw.
Old Feb 17, 2008 | 09:31 PM
well if the odometer works its probably the gauge itself. the odometer works off of the speedometer. so its probably something in the gauge cluster. but the vss is on the top of the transmission. its a little grey connector.
Old Feb 17, 2008 | 10:53 PM
s0ulj3r's Avatar
Ok thanks, i might have gotten it a little wet, went through a couple bigger puddles lately, ill let you guys go afte ri mess with it.
duneracer69
Dec 22, 2010 04:33 PM
GRANDE7652
Apr 6, 2009 11:01 AM
hondaboi7
Mar 18, 2009 09:06 PM
stivic
Oct 5, 2008 05:25 PM
junya16
Mar 5, 2003 08:42 AM
