Remote start activation question.
first off this is a hornet 564t alarm system with a 99 honda dx with no factory alarm or power anything. ok now there is this strange metallic spring loaded thing that i have to wire in to get my remote start to work,
and the installation guide says to wire it like so -
the book says it the wire going to this needs to have 2 consecutive ground pulse in order to start, how do u think i should go about wiring this thing in?
so far im think of grounding the metal thing and just simply attaching the wire into the bottom connector.
thanx
thanx
2 ground pulses? In what time interval? Is this switch supposed to act as a trigger for starting?
Typically, that switch you have is a hood sensor.
When its open, it provides a ground.
When you press it, the contact is broken.
(I sold a crap ton of those switches on here a long time ago)
the picture is of a hood pin like said above. That cut s off the engine when the hood is popped.
the other pic you have is of the valet switch or so it looks like. that gets hidden inside the car somewhere so if your remote dies you can turn off the alarm by putting the key in the ignition and turning the key.
so can one of u guys explain how the remote ignition works, bcuz ive cut the strtr wire and attachted the appropriate wires, but i have no remote or regular ignition. i have a wire connected to the brain thats white/blue, and it needs to be atached to the consecutive ground pulses, how do i do that? ground it twice? lol
this is the only thingg that stands in the way of me finishing installing my alarm system with no knowledge of alarm systems. - so plz help...
not familiar with your model r.s. but the white/blue wire your talking about sounds like its for activating the r.s. from an external source. is this a stand alone remote start or r.s. alarm combo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roachsboosted16 »</TD></TR><TR><TD CLASS="quote">it has a brain and a satallite relay for the remote start, 2 modules</TD></TR></TABLE> thats not what i asked you. is it a remote start only or an alarm remote start combo. i do aftermarket electronics for a living so if you answer the questions i have i can prob. help you, but like i said i'm not familiar with hornet. regardless the main differance between most system is just wire colors for a specific function
chocolatesk8er10
Audio / Security / Video
Apr 29, 2009 10:23 PM
