valvetrain taping
Old Feb 17, 2008 | 04:30 AM
zccr-xsi's Avatar
Default valvetrain taping
ok ive been wroking on this accord for few days now,it has a loud *** taping sound coming from the valve cover.ive already took off the cover and looked at the rokcer ***. and evrything checked out ok.readjusted the valves too what the book said which was .0010 on the intake and .0012 on the exhust.reinstalled the valve cover and still taps like someone throw a marble in there.whats funny is when u get in the car and put it in drive it quiets down a little,when it goes in 2 gear it seems to make little to no noise.motor is throwing no codes and runs just fine except for the loud *** tapping sound.
ok im wondering now if it could be a broke spring or spit retainer?i have started it with the cover off and couldnt see where the noise was coming from im thinking its coming from somewhere i cant see.ive also tried pulling number one plug wire and trying to start it all is does is try to turn over and doesnt make that sound untill it gets started.when it is started i can put my hand over the cover in the center right ontop of 2 and 3 and i can feel it tapping,then i put my hand over 1 and 4 and i cant feel ****.anyone have any clue what this could be.ill porb. end up just switching out the heads and see what happens.btw its a 90 zccord with a sohc 2.2l F22a.
Old Feb 17, 2008 | 05:18 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: valvetrain taping (zccr-xsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zccr-xsi &raquo;</TD></TR><TR><TD CLASS="quote">readjusted the valves too what the book said which was .0010 on the intake and .0012 on the exhust.</TD></TR></TABLE>
I hope you meant .010 and .012?
Not sure about the tapping.
Old Feb 17, 2008 | 05:38 AM
zccr-xsi's Avatar
Default Re: valvetrain taping (TouringAccord)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TouringAccord &raquo;</TD></TR><TR><TD CLASS="quote">
yea sorry i put in one to many zeros im woindering if i should just save myself the time and get a head from the junkyard and throw on there.
fyi the car is going to be sold this aint my car.i just want to fix it so i wont tap.
Modified by zccr-xsi at 9:59 AM 2/17/2008
Old Feb 17, 2008 | 11:08 AM
BlUAc's Avatar
did you happen to see if the rocker assembly is torked down to spec
need a head got one to get rid of
Old Feb 17, 2008 | 12:38 PM
Lapog's Avatar
I think I have the same problem. The car runs fine, with good mileage and power. The noise bothers me. The valves are in spec too. Perhaps the rocker arms are worn out and needs replacement?
Old Feb 17, 2008 | 02:48 PM
SOHCMAN's Avatar
Mine always has a "tapping" in the winter and the seems to vanish come summer. Its accentuated by a cold engine and lessens as it warms up. I think its just the valvetrain tapping due to extra clearances from cold parts and a colder running engine in the winter.
SOHC
ps. also no codes, good mileage... a Honda mech. told me it was a characteristic of the F22 engine...
Old Feb 17, 2008 | 05:21 PM
Bulli Kid's Avatar
Default Re: valvetrain taping (BlUAc)
valves?
Old Feb 17, 2008 | 06:03 PM
zccr-xsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlUAc &raquo;</TD></TR><TR><TD CLASS="quote">did you happen to see if the rocker assembly is torked down to spec
need a head got one to get rid of</TD></TR></TABLE>
ok i did break the rocker assmbely lose and retq everything the motor has power just tapinglike a bitch.when i had the cover off i didnt see anything out of the unsaul.how much for the head?does it tap too,ill be pulling the head tomroow ill get some pics and post them up.when i pull the head it should give me better ideal whats going on.
Old Feb 18, 2008 | 07:14 PM
The_Honda_Guy's Avatar
Obviously during the winter the clearances between certain parts is going to be great since they are contracting from the cold. The valve clearances are going to be larger during the winter, which obviously is going to make the valve train "clang" louder than in the summer. As long as you have the valves adjusted correctly and have the rocker arm nuts torqued down correctly you should be fine. I haven't seen a Honda with 100k+ miles on it yet that didn't have a valvetrain clatter. I'm pretty sure if you heard my car right now when it first starts up in the cold you'd think something is quite broken.
Old Feb 18, 2008 | 07:39 PM
rockybalboa11's Avatar
Default Re: (The_Honda_Guy)
the majority of i4's that i hear running down the road all sound like this.
my brand new '08 civic has this noise. maybe not as distinct as a marble, but there is still a faint tap tap tap with the radio off and the air blowing softly.
the oil change i just gave it has made the noise less apparent. but it still remains.
Old Feb 19, 2008 | 02:32 AM
zccr-xsi's Avatar
really my dohc zc dont tap like this,i mean u can hear the inj. clicking but other then that the zc is quiet.is this just something that happens with the older f22a?ok i did get the cam out and got good look at all the springs,i found on number 3 cyl. intake spring looks like it messed up.ill get my buddy to take some pics with his good digi and post them up to see what yall think.resaon i know there something messed up with it is his g/f has the same year accord and that car dont make sounds like this.
Old Feb 19, 2008 | 06:37 PM
Lapog's Avatar
Default Re: (zccr-xsi)
Does this indicate that the valves were 'tapping'? How bad was the spring. Please post the picture... that's certainly be useful. Thanks!
Old Feb 20, 2008 | 07:48 AM
professorman's Avatar
DOHC engines always sound nicer because they are more balanced.
Old Feb 20, 2008 | 09:34 AM
zccr-xsi's Avatar
ok there seem to be nuttin worng with the spring ir valve ill prob end up trying a head head.btw guys u think a worn out rocker assabmly could make that noise?
Old Feb 26, 2008 | 12:04 PM
Lapog's Avatar
Did you find out what was the problem? I am waiting with bated breath to start on my 95LX. The noise is bothering me...
Old Feb 27, 2008 | 01:51 PM
Klepto666's Avatar
i aslo have a 90 accord with a F22a w over 300 thousand miles on it and it taps, everyone that i talk to around here say that hondas tap and there is not much u can do about it no matter how many times u adj them they just tap. so i just got used to it, motor runs great so i really dont care too much
Old Feb 27, 2008 | 02:43 PM
Morthren's Avatar
I've got two 1990 accords one with 195k miles on it the other with 76k miles and in the cold they do sound louder. I read somewhere that this was a characteristic of the F20 & F22 engines (F20 engines are used on the euro versions which I have) Funny thing is, my 76k motor had the timing belt snap and was redone at the dealer with new valves and everything and since then it taps louder then the motor thats done 195k. It sounds more like the camshaft is floating around then the tappets so not sure whats gone on there
Is the sound definately coming from the valve cover? could it be a noisy injector?
Old Feb 27, 2008 | 02:57 PM
zccr-xsi's Avatar
naw it aint a inj i know that for sure. well im going to get a head from the j/y thisweekend and see what happens.
Old Feb 28, 2008 | 09:44 AM
Lapog's Avatar
Yes, its louder when cold and kind-of settles down when warmed up.
I also have this odd 'synchronization' buzzz sound. It lasts for a fraction of a second, and is audible when the car starts to move and just before shifting to 2nd gear. Feels like two moving gears are synchronizing....
Tealmist
Sep 8, 2017 07:22 AM
KodSol
29
May 4, 2012 02:54 PM
kwikiimart
Jul 16, 2010 10:32 PM
yohan
Sep 24, 2007 11:50 PM
johnnycivic66
Nov 24, 2004 11:51 PM
