metal on metal grinding coming from under the valve cover
Okay, so i started my del sol d16z6 and heard a metal on metal grind which i thought was from the under the car, maybe from the exhaust hangers. disregarded it until i started driving down the road. get to about 3000 rpm and the noise gets louder. pull from a stop sign and starts to feel as if I lost a cylinder, but didn't sound any different. Pulled to the side of the road after it dies on me. Now i start thinking. start the car back up, grinding noise is louder and realized its not the cylinder. as i get towed, started the motor with my dad listening to the engine bay. he said the noise was coming from under the valve cover. Valve, valve spring, rocker arm....? No idea. Get home after work and take the valve cover off. Don't see anything out of the ordinary. Best idea to pull the head off? i haven't gotten this far into my motor before, so i don't want to be F'ing **** up. I somewhat understand how to take it all apart and put it back together, but just want to make sure its done right. Anything to do after taking the valve cover and then pulling the head? anything that I will need to take off prior or will everything stay together to look at the valves? Thanks HT, i appreciate all the help. I WILL be as careful and particular as POSSIBLE! Want this is be fixed the right way.
Re: metal on metal grinding coming from under the valve cover
You should do a leakdown test to try to find which cylinder it is. You could have dropped a valve, broken a valve seat or sucked something into one of you cylinders. You could also remove the exhaust manifold and intake manifold to check the valves before tearing it down, but you are probably going to have to do it anyway.
thats what my dad was saying. take off the exhaust manifold. thanks. doing it tomorrow
Sounds like a broke valve that went through your motor, exact thing happened to me when I had a b16 eg hatch.. Except when my car died, I couldn't get it restarted.
Pull the intake/exhaust manifold, take a better look at the head with the valve cover off. Pull the plugs and manually turn the engine over and look to see if anything is out of place, or not doing what it's suppose to. You may even get the sound it was making to an extent. Might as well inspect the valve lash as it may have become extremely loose.
I pulled off the valve cover already and pulled the plugs. turned it over..all the valves/rocker arm/springs moving as they should. nothing looked out of place. im going to be taking off the intake/exhaust manifold to see what I can find. Haven't heard the sound at all. only time i heard it was when i had the motor past 2500rpm or so. so i haven't heard it since i took the valve cover off. ill update once i see with the intake and exhaust manifold off. thanks guys
Could be a bolt backed out somewhere and was rubbing (clutch/torque plate, timing cover) then snapped off or wore through..
Don't start jumping to conclusions and doing an unecessary tear-down..
Just worked on a car with a scraping/knocking noise coming from the engine. Got my stethascope and narrowed it down to the alternator/bracket. Went to remove the alternator and found out the main pivot mount bolt that holds the alternator on was missing. Only thing holding it on was the adjustment bolt and belt tension. $7 and a trip to the Honda dealer and it purrs like a kitten again.
compression is good on all cylinders. put everything back together..started it up..didn't die. the knocking noise is RIGHT under the valve cover..almost sounds like its hitting the valve cover..between cylinder 2 and 3..right in the middle. pulled the valve cover off again and looked under it..no marks that would indicate knocking against the valve cover. thats where the noise is coming from..can feel it right under the valve cover. confused. its definitely a knocking now..not a grinding. the motor was a little low on oil..no oil light, could that have made grinding/screeching? filled up and no screech..now just the knocking.
and its not stalling out either now. which it was doing when this problem first started.
Can you hear it under the car as well? Hopefully it's not a rod/spun bearing. I'm thinking the valve may be damaged if it's not a low end problem.
Do us all a favor, buy or make an engine stethoscope, and steth the motor to figure out EXACTLY where the ticking is coming from.
Or that.
For anyone out there that doesn't know what we're talking about, the next time you're bored, go pick up a couple quarts of oil. When you get back home, open your hood fully (use the lower prop point, not the main prop point), take off the oil cap, and start the car. Get ready for black fireworks.
