brake question
I did a wire tuck on my 94 civic bay and i am in the process of figuring out how to fix my braking system. I was a dumb azz and decided to cut the lines when I was removing the abs. Is there any way that I can fix this or how can I set up brake system with Earls Fitting like I see a lot. What sizes do I use. HELP
you really need to better word your question.
you cut your abs lines? you mean the wires on the control arms? wtf?
stainless fittings? you mean stainless brake lines? or to the mc? wtf?
seriously.
seriously.
i cut the hard lines that came from the abs and went directly to the brakes. All I have left now are 4 cut brake lines still attatched the calipers. I need to change my brake set up to one that doesn't use abs. i have read that I could use a Integra RS proportion valve and the hard lines and my brakes would be fixed.
I basically need to run new lines from the master cylinder to the brakes, but I don't know what I can use since I had ABS before and now I don't. Thanks i hope this makes it a little clearer.
FIBAH
Feb 25, 2017 05:53 PM
EL-Driver
Feb 5, 2002 05:18 PM
