Head Gasket finished now problems
Old Feb 16, 2008 | 08:06 PM
iwanttogofast's Avatar
Default Head Gasket finished now problems
i got a rust free 1991 CRX Si 1.6L for free but it had a blwon head gasket, i fixed it and it runs but after it warms up and you shut it off it steams but there is nothing that is broken. coolent leaks on the ground but i cant find where it is leaking from any ideas??? could the top of the block be warped?
Old Feb 16, 2008 | 08:13 PM
alscrx's Avatar
Default Re: Head Gasket finished now problems (iwanttogofast)
First, does the car overheat now?
Do the fans turn on?
Old Feb 16, 2008 | 08:22 PM
Default Re: Head Gasket finished now problems (alscrx)
no over heating and it runs. it runs just as good as anyones car it just steems from where the thermostat housing is at but i cant find any leaks.
Old Feb 16, 2008 | 08:29 PM
alscrx's Avatar
Ok so i see you said the coolant leaks on the ground so there is a leak that must be dealt with. Put a peice of cardboard down under the car with some weight on it to hold it in place. This will then at least show you the location of the leak.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iwanttogofast &raquo;</TD></TR><TR><TD CLASS="quote">no over heating and it runs. it runs just as good as anyones car it just steems from where the thermostat housing is at but i cant find any leaks.</TD></TR></TABLE>
Check your thermostat....get a new housing gasket and reseal
Old Feb 16, 2008 | 08:33 PM
zrickety's Avatar
I have seen hair-line cracks in blocks that will weep or leak, almost invisible to the naked eye. But first check that thermostat housing and replace the gasket
Old Apr 2, 2008 | 04:53 PM
acmoc's Avatar
maybe the radiator drain plug is a little loose, radiator cap not sealing rite, hose, or maybe it's your radiator that needs to be replaced . Good luck,
deades2010
Jan 26, 2010 12:06 PM
d16y8EL
Mar 29, 2007 06:55 PM
racingfan
Sep 3, 2006 11:27 AM
ALMXDUPINTEGRA
May 11, 2005 11:05 AM
