darton sleeved 84mm b18c, p72 head w/ gsr cams, peakboost kit.....Start up NO OIL PRESSURE HELP!
not sure what the prob is. no oil leaks. please throw out some suggestions for me guys. big issue here ..... Thank you so much in advance!
oil level seems to be good....
took the oil feed line off the turbo and it had maybe 2 drops of oil in it.
checked inside head... no oil has obviously flowed through it other than the oil i poured in it.
where did you pour the oil in the head? just wondering because im going to be starting my new block up pretty soon for the first time. sorry i cant help you....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91b20bintegra »</TD></TR><TR><TD CLASS="quote">you did prime the oil pump didnt you?</TD></TR></TABLE>
yes, i turned it over with no ignition twice for 10 seconds each. I changed the oil filter, the other filter had oil in it so obviously the pump circulated oil to the filter. But when i removed the oil feed line on the turbo like 2 drops of oil came out of the line. i got the connection of oil feed off of the oil pressure sensor in which the oil pressure light is on....
reply to first response.... in the oil filler cap.
thats a good question and judging that the block was sleeved... i would bet the builder forgot to put them back in... time to drain the pan.. I will be able to see it if i remove the pan, pickup, and sheild. correct?
the pistons had about 2 caps of mobil 1 sitting on top of them. i pray to god these rings aren't gone. only about 40 seconds of in consistant run time on them... 5 seconds here and there... what cha think/???
is this a new build? You should take off the valve cover to see if there is any oil. Maybe the oil is just too clean. Happen to me on my build on the first start up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litovi3tboi503 »</TD></TR><TR><TD CLASS="quote">is this a new build? You should take off the valve cover to see if there is any oil. Maybe the oil is just too clean. Happen to me on my build on the first start up. </TD></TR></TABLE>
He didnt say there wasnt any oil, he said there is no oil pressure. According to him it has oil in it already.
lil'Joe1039
15
Mar 17, 2007 12:05 PM
