Shifter Bushing
I believe it's a specialty part meaning you'll need to order it through the dealership. You'll need that dust boot as well as the collar inside.
http://www.sonsacuraparts.com
54115-SH3-000 DUST SEAL B, CHANGE
54110-SH3-003 SEAT, CHANGE LEVER BALL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">54115-SH3-000 DUST SEAL B, CHANGE
54110-SH3-003 SEAT, CHANGE LEVER BALL </TD></TR></TABLE> where was this when i installed my first shifter 7 years ago? lol. anyway, you will need that piece without it, your "short" throw shifter won't seem so short. that seal helps hold it in place, i guess acting as a force to go against when going in and out of gears, like it holds the shifter where it is. without it the throw seems sloppy.
Actually, the dust boot holds in grease (lithium) and pivots the shifter on the stabilizer bar. Without grease in the boot, the shifting will be very tough and notchy.
ok the holding grease makes sense. but why when i tore the rubber i put the shifter in just to go to the store, and my throws seemed further and really sloppy compared even to stock? i'm not disagreeing with you, but i guess questioning my own experience.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhammond_82 »</TD></TR><TR><TD CLASS="quote">ok the holding grease makes sense. but why when i tore the rubber i put the shifter in just to go to the store, and my throws seemed further and really sloppy compared even to stock? i'm not disagreeing with you, but i guess questioning my own experience. </TD></TR></TABLE>
without the boot, did the shifter drop? Like did you have to hold the shifter up to shift gears because the shifter didnt want to stay there? Thats how mine is right now, I dont have the boot
no mine didn't fall down. do you have those two bolts that hold the shifter in place on there. i think its like 2 10mm bolts on a bracket that hold the shifter up.
Yeah, basically you have the stabilizer bar and you have that plate beneath it (2 10mm bolts). Those two sandwich the dust boot in making everything tight. Without the boot, there will definitely be a lot of play.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northemt88 »</TD></TR><TR><TD CLASS="quote">junkyard</TD></TR></TABLE> that would be my guess too. i know advanced and autozone do not carry those.
mraza
18
Apr 10, 2007 08:53 AM
